All New 2010 X6 Linear Standard/Plus/ATC optional/BT30 10000rpm Spindle
New x6 linear machine present. compare old x6,it is update and we can see it is a new machine.
Table size 690×210mm
T slot QTY /width/center distance(mm) 3-16-63
Maximum load(KG) (kg) 100
X travel (mm) 330
Y travel (mm) 220
Z travel (mm) 320
Spindle nose to table (mm) 90-410
Spindle center to column (mm) 280
Spindle taper BT30
Max. spindle speed (Rpm)6000 or 10000(ATC model)
Main motor (kW)2.2
Servo optional.
X torque(N.M) 3.3
Y torque(N.M) 4.0
Z torque(N.M) 5.0
machine weight: 700kg
it is new and lead of this kind middel size cnc,
include industry spindle and package of ATC update.
later will have full encloser.
we use blance block to replace the gas spring.and update automatic oil to be standard parts.
syil all northamerica dealers have been in stocking.
the soonest delivery to US mainland will be at september.
the demo model also will present IMTS machine show in chicago.
Syil China.
Direction,Commitment,Follow through
