585,977 active members*
4,180 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 3016 ballscrew backlash
Results 1 to 7 of 7
    Nov 2009
    24
    I recentely purchased a fadal 3016 and it has quite a bit of backlash in the ballscrews, when I put an indicatior on the end of screw and jog I get about
    .018 in both directions X and Y, The ballscrews themselves seem to be in good shape, how can the thrust be adjusted out.
    Any help would be appreciated
    900
    Daniel--
    If you have that much play, you have big issues. First make sure you are testing correctly. For the X axis with the mag base on the table place the indicator on the end of the ballscrew. do a push pull test in the X axis and read the B/L. This is checking the ballscrew to the ballnut. Now place the mag base on the saddle and indicator on the end of the baLLscrew. You are now testing the thrust bearing slop.
    Repeat simalrly for the Y axis.
    Also, verify that there is no rotation slop in the coupler.
    Neal
    Mar 2010
    backlash
    sounds like the thrust bearings are shot,if there are dowfrost lines going to the bearing blocks they are metric pitch screws and the ones without lines are inch pitch.you will need to know to order the bearings and seals.the bearings are easy to replace all you need is a arbor press.if the screws are moving in and out more than .002 replace the bearings.if you decide to do the repair yourself post or pm and i will give detailed instuctions.if the slop is not as much as you thought you can adjust the backlash.go to enter next command enter BL this bring up the backlash table.test backlash in jog at the center of the travel with an indicator one click each way and adjust the value.to adjust go to BL and for example x axis is adjusted by typing BL,1,(value here) the ends of the travel are done an inch from the end and the value is typed in the bl line seperated by comas.to do y axis type BL,2,(value) and z is BL,3,(value).the manuals can be downloaded from fadalcnc.com for free.
    Nov 2009
    24
    Smile
    Well you both were correct the coolant lines that went into the thrust bearings leaked water into bearing and took them out in a big way, replaced both axis bearings and adjusted backlash, back in business, Thanks for all your help.
    900
    Daniel--
    Make sure that the DOWFROST is not leaking or you will knock the new bearings out quickly!!
    Neal
    Jan 2004
    3154
    There are a bunch of us here that bypass the ballscrew cooling to eliminate that issue.
    This works well unless you run the machine hard and a couple of shifts a day.
    The cooling is a great idea but difficult to keep from leaking, especially in older machines.
    www.integratedmechanical.ca
    Apr 2008
    1577
    Quote Originally Posted by Daniel Boone View Post
    Just did the same thing to two of my Fadals. The X axis on one machine and the Y on the other.
    On one machine there was a small groove wore into the ballscrew so it will eventually fail again.
  1. VMC 3016 communications
    By ttorqueshop in forum Fadal
    Last Post: 11-24-2007, 05:23 PM
  2. Ballscrew backlash, need suggestions.
    By magick_man in forum DIY CNC Router Table Machines
    Last Post: 05-05-2007, 11:36 AM
  3. Building zero backlash ballscrew nuts.
    By dcprecision in forum Linear and Rotary Motion
    Last Post: 09-08-2006, 11:19 PM
  4. Backlash for a rolled ballscrew?
    By Zumba in forum Linear and Rotary Motion
    Last Post: 03-20-2006, 10:41 PM
  5. Ballscrew or Backlash Compensation?
    By RXTurbo in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2004, 11:47 PM
