585,712 active members*
4,014 visitors online*
Results 1 to 19 of 19
    Mar 2009
    76
    Citizen Question
    For the Citizen experts. Is there a way to incorporate the cutoff process and start position process directly into the program rather than having to do it manually?
    What macros does it read for the cutoff, and for the move to start position? These questions are for a L20 M7 and M8
    Thanks in advance
    Brett
    304
    Yes there is a way.
    Load the attached file into the machine and call it as a SUB program at the beginning of $1. MAKE $2 WAIT UNTIL IT IS COMPLETED.
    $1 ................................. $2
    M98P322
    !2L322 ........................ !1L322
    This is for the L7-20. There is NO M7 or M8 machine.
    You need to call the cutoff tool into position and position the stock FIRST!!
    Attached Files Attached Files
    Mar 2009
    76
    Thanks for the reply. I new to citizens and was referring to the model # on the manuals, it says 5m7 or 5m8 which is where i got the m7 m8 from. Anyway thanks for the information. And what excatly is program 322?
    If i have to position the cutoff tool first would something like this work
    $1................................................ .................$2
    IF[#5041LT0]GOTO500......................................!L322
    T0100
    G0X[#814+.05]
    M98P322
    N500
    !L322
    Mar 2009
    76
    My goal in this scenario is to put a safety check in place in case guys forget to move to start position which seems to happen regulary.
    Mar 2009
    76
    OH
    Didnt see the attached file! Thank you!!
    304
    This program will got into alarm if the cutoff tool is not in position. The screen will read "Call Cutoff".
    If you do a tool call as you show it will add cycle time on EVERY cycle.
    FYI,
    5m7 = L5-20 (5th Generation L20), Type VII
    5m8 = L5-20 (5th Generation L20), Type VIII (Added capibility, Gangblock)
    See the attached file for a line-by-line explanation of what will be done by that program.
    "Train the operators, but first protect the equipment!"
    The M stands for Mitsubishi, F stands for Fanuc
    Quote Originally Posted by cogsman1 View Post
    FYI,
    Just to expand on your breakdown, M is for Mits, F is for Fanuc
    Jan 2009
    34
    I am trying to use this on my L6-32 but i am having trouble with the G53 -#818. It wants to go to minus what is in my mc data from machine zero. It is not going to the start position.
    304
    For that machine change that one line to be
    G53Z#872-#818
    The system settings are different between some models.
    Jan 2009
    34
    thank you. I am trying to learn how all this stuff works. Kinda got thrown to the wolves with the swiss machines. Learning as i go though..
    Jan 2009
    34
    I am still having problems with this on the L6-32. I changed the g53 line to #872-#818. The first time I ran the program it worked just like it should, went right to start position after cutoff. Now every time after that It wants to go forward toward the guide bushing and alarms out.
    Feb 2008
    267
    what alarm?
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Jan 2009
    34
    Z axis over travel. Traveling toward the GB this time.
    Feb 2008
    267
    Well, are you in OT?
    Can you move Z1 in manual?
    When you run your code, what is the MC COORd for Z1?
    304
    What does the "distance to go" show? What axis' still have movement to go?
    Jan 2009
    34
    just Z1 axis list a distance to go. It is something like 10 inches positive. If i go back to G53 z-#818 it also alarms but a negative distance to go.
    304
    There are only two options and one of them is correct. Be sure you are entering them in correctly.
    G53Z-#818 (Z - #818 )
    G53Z#872-#818
    Jan 2009
    34
    Ok i am certain i have entered everything in correctly. Like i said though if you do this first thing when the machine is powered up it works. if i manually do a start position or if i run this start position prog twice, the second time it does not work.
    Here is what i just took out of the machine
    O322(START-POSITION )
    $1
    IF[#858NE#816]GOTO30
    IF[ABS[#5043]GT[#814/2]]GOTO30
    IF[#5043GT.01]OR[#5043LT-.01]GOTO1
    IF[#5041GT#824+.02]OR[#5041LT#824-.02]GOTO1
    GOTO7
    N1
    M6(CLOSE COLLET)
    (CUTOFF)
    T0100
    S1=#817M3
    G0X#814+.1T1
    G99G1X#824F#822
    G4U.5
    M5
    N7
    (START POSITION)
    IF[#5022EQ-#818]GOTO991
    M7
    G4U.8
    G0X#824W0T0
    G53Z#872-#818
    M6
    N991
    M99
    N30
    #3000=70(-CALL-CUTOFF)
    $2
    $3
    $0
    A
    #814=0000007500
    #815=0000001000
    #816=0000001000
    #817=0003000000
    #822=0000000020
    #824=-000000500
    #818=0000015000
    #819=0000001000
    #820=0000000000
    #821=0000000000
    #990=0000030000
    #991=0000056000
    #992=0000064000
    #893=0000000000
    304
    Try this change
    (START POSITION)
    IF[#5022EQ[#872-#818]]GOTO991
    Let me know the "Machine position for Z1 when you do a normal "Start position" and the "Machining length" from your MC DATA IF this does not work.
  1. Citizen M32
    By shrektaylor in forum CNC Swiss Screw Machines
    Last Post: 12-09-2014, 06:13 PM
  2. Citizen L25
    By JOlalde in forum CNC Swiss Screw Machines
    Last Post: 06-13-2010, 12:09 AM
  3. Citizen L20
    By Tornos100 in forum CNC Swiss Screw Machines
    Last Post: 04-24-2010, 06:52 AM
  4. Citizen M series basket and counter Question
    By EdgeCrusher in forum CNC Swiss Screw Machines
    Last Post: 12-17-2009, 12:44 AM
  5. Citizen L25
    By appusivadas in forum CNC Swiss Screw Machines
    Last Post: 07-16-2009, 02:51 PM
