584,865 active members*
4,954 visitors online*
Thread: TORQ-Cut-22
Results 1 to 7 of 7
    Feb 2008
    204
    TORQ-Cut-22
    In another thread i stated I had issues with my Torq-cut 22 after it sat a month
    when i started and it back up the z axis would drop when I enabled the drives.
    It would then kick out with an error.
    This all started when I started it up and the machine said there was no op system.
    After a couple trys it booted up to where the problem started with enabling the drives.
    Now I get as far as the executive load and then to the c propmt.
    The bmdc wont load.
    I have always got a quick message at the ds32 screen after boot up about a dos/bxt/font load error,
    it used to be so fast I could not see what it was saying
    now it hangs there and tells be dos/bxt/font
    loaded to block 0
    loading operating interface
    than to the c:>
    I searched old forums on here and found a post George had made:
    You should switch to dos using ALT and TAB then run RUN.BAT which should load the machine software
    under DOS and not windows. This loads the correct fonts that the machine software needs.
    Now i am wondering if this could be part of my problem.
    At the c:>I can run btc.exe and get this back
    low data address reg test failed
    data should be 1a5 data is 0
    hi data address reg test failed
    data should be 5a data is 0
    dual port memoty test #1
    at side dual port ram ok
    machine check.....not running
    executive load...wait then c:
    I also get crc error in data reading c:
    I also had the power supply for the motherboard go bad during this and had to replace.
    I am not sure if the bmdc is bad or thr pc just dosent reconize the bmdc
    When i power up the machine there is a red led on on the bmdc that goes out on load up fail.
    Nov 2004
    3028
    See if you have the B3T.exe on your hard drive. This is a BMDC test piece of software.
    Try running that.
    I have been looking at the schematics. i would look harder for CR1. it seems to put power to the Pwmint board which turns on the drives. Check the overloads in the top left hand corner of the machine as well. (page 3 of the schematics)
    If the CMOS is corrupted then the PC side of the machine will not be able to read the hard drive correctly and thus load the software to the BMDC and to memory. Same if the hard drive has some scrambled software. Check the CMOS and try going to the DOS directory and running SCANDISK and DEFRAG.
    George
    15362
    tpmx57
    Pm sent, We have BMDC boards, But should test your board first
    Mactec54
    Feb 2008
    204
    George,
    The results I show below are from the B3t.exe not btc.exe.
    Mactec I did get your pm and thanks.
    Right now it appears my harddrive is going bad.
    Worked a little tonight with the mill and am having errors on the drive.
    I have a dom for it that I am going to put in it.
    I have a hardrive copy from when the machine ran fine to copy to the dom.
    I have to figure out how to go about doing this first.
    Thanks for the responses
    Aug 2017
    Hello, I have a machine "bridgeport tor cut 22" the HDD is damage,
    and I lost all the data of it.
    I managed to install the Dos 6.2 and recover some of the files, but to recover the complete system i need all the files.
    can you help me?, sending me a backup of the software to this email address: [email protected].
    Would appreciate your help, thank you.
    isaias torrealba
    I need that software is necessary to start it,
    the machine is from my university and it would be very helpful if we could repair it
    Aug 2017
    isaias torrealba
    Aug 2017
    Post torq cut 22 help
    isaias torrealba
  1. Torq-Cut - Help Needed
    By Engine Tech in forum Bridgeport / Hardinge Mills
    Last Post: 01-04-2012, 07:43 PM
  2. Torq cut 22
    By Dirtman in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2010, 12:53 AM
  3. Need help! Torq cut 22 TLO..
    By Freewheels in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2009, 06:00 AM
  4. TORQ-CUT 22 Problems
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2009, 02:13 AM
  5. DNC to TOrq Cut 22
    By Drexelracing in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2009, 11:51 PM
