I have a mid 80's LC-40 with an OSP5000L control. It was working fine on Thursday night and the next morning on startup it alarms as soon as it starts up with "166 Alarm A - Revolution tool SDU". The manual states the issue is with the SDU (spindle drive unit) for the live tooling.
I open the case and the SDU has 3 green and 4 red lights in a row. The 2nd and 3rd green lights are on, and the 2nd, 3rd and 4th red lights are on. The other SDU (for the main spindle) just has the 2nd and 3rd green lights on.
The red lights mean
2nd - OS (overspeed - manual says to check tach brushes)
3rd - PH (phase loss - manual says check for blown fuses)
4th - IOC (instantaneous overcurrent, check DC motor brushes and check SDU-600W unit)
Any ideas?
I have never used the live tooling. Is it possible to bypass the error somehow? I don't use the live tooling so if the SDU for that isn't working I don't care so much. Perhaps there is a parameter to turn off the control's awareness of the live tooling and associated servo and spindle drives?
Also, this lathe has 2 turrets (upper main turret, lower 8-tool turret). I knew the lower turret didn't work, the seller told me he was told it needed a new servo controller. The lower turret would move in X but not in Z - if you tried to move it in Z it would just immediately alarm on the control and the servo driver had some error lights on. I moved it in X when I got it but haven't moved it since (about 2 years).
When I open the cabinet today, I noticed that the error lights were on the XB servo driver as I expected. I also noticed they were on the ZB servo driver - so that is something new, apparently, although I'd never have noticed). There are also lights on the C axis servo drive. First, I can't imagine why the C axis has a servo drive? I'd have thought it would be part of the SDU for the spindle? But the same lights are on for all three of the servo drivers. The only servo drives that seem OK are the XA and ZA (which are the only ones I use).
But it makes me wonder - are these servo drivs (LDU-600) prone to issues? And if so, what causes the failures? I am very handy with electronics so I have no problems testing parts or replacing components on the circuit board - but I don't know where to start. On my old Leadwell mill, the high-power transistors were known to fail over time. I noticed on the SDU there are several small black things with screw terminals on them with wires... looks like high power transistors. Are these the potential culprit? Anyone got any suggestions on getting diagnosing the drives myself?
Thanks!
