585,997 active members*
5,068 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA 4-AXIS ISSUE.
    Oct 2007
    19
    OKUMA 4-AXIS ISSUE.
    Hello All,
    How do I disable one of (2) double drives(BLII-D) on a Okuma lr-15 with a 5020L control. I cant get to the parameters because of the alarm 65 on the control. Just want to run one turret with the good drive is all.
    Thank you in advance
    WT
    Mar 2009
    1982
    it is about OSP specification code correction. You need to ask Okuma representative about that.
    This lathe is not 4-axis. Just double turret. Turret A maybe with M-tool function.
    Oct 2007
    19
    Unhappy THNAKS Algirdas FOR THE REPLY.
    BUT, THIS LATHE IS 4 AXIS. HOW DO I GET PAST THE ALARM CODE 65 SO I CAN GET TO THE PARAMETERS. THIS MACHINE NEVER FINISHES BOOTING, AND GOES RIGHT INTO ALARM 65.
    Mar 2009
    1982
    Sorry, my mistake about 4 axis. I know only one machine of that kind. Your's is different. "code 65" gives no glue about alarm on boot. You can boot up OSP with emergency stop activated in case, if there is no SVP error.
    CPU, bus and communication errors also brake boot up process.
  1. Okuma Howa 2SP 20H - Parameter issue
    By davey242 in forum Fanuc
    Last Post: 02-21-2014, 06:46 AM
  2. odd X Axis issue
    By smittys800 in forum Fadal
    Last Post: 08-04-2009, 06:42 PM
  3. DIY controler X-axis issue
    By KsiR in forum Stepper Motors / Drives
    Last Post: 02-20-2008, 03:56 AM
  4. Y-Axis issue
    By studysession in forum Machines running Mach Software
    Last Post: 12-28-2006, 09:11 PM
