585,917 active members*
3,321 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > DynaTorch > Changing rapid travel height at the machine
    Dec 2009
    35
    Is there a way to change the rapid travel height while at the machine? I've never worried about it before, just let it raise all the way up and figured reducing the chance of hitting a tip up is worth a little extra time. Now I've got some work with several hundred small holes and no chance of a tip up on most of the nest so a few seconds saved on each hole would really add up.
    Thanks in advance.
    Mar 2009
    924
    Go to setup>machine settings>homing tab. On the Z settings of "offset inches" put in the height you want the torch to go to after homing and hit "apply". then close that window and go back to setup>search for home>find Z home. The torch will raise to the hard stop and then drop down away from the hard stop the specified height. On original set-up, you probably did .25" offset. There may be another way but that is what I do to be quick. Keep in mind that it will home to that position until you change it. It does save LOTS of time!
    WSS
    May 2010
    If you look in "Custom" tab (still in Machine Settings screen), look at M125 and it will explain how to set it in a cutting file.
    Basically, you add a line of code within the first few lines of the program: M125 P** . Whereas the ** is the height that you want the torch to lift between cuts. For example M125 P1.25 would raise it 1.25". I set this value depending on how large any drop-outs might be in my part so that the torch won't catch them while traveling if they stick up.
    Mar 2009
    924
    Quote Originally Posted by travis11 View Post
    Good to know! The way I was doing it, the number was away from home. The M125 code is helpful for quite a few situations. Great idea to size up the drop to match the retract height.
    WSS
    Dec 2009
    35
    Thanks guys!
    I used the first method today and will check out the M125 code tomorrow.
  1. Delta 20 rapid travel
    By jdracing in forum Dynapath
    Last Post: 04-17-2010, 01:36 AM
  2. Need Help With Non Functioning Rapid Travel
    By Todd H in forum DNC Problems and Solutions
    Last Post: 12-11-2009, 09:29 PM
  3. rapid travel question
    By fokusco in forum Haas Mills
    Last Post: 09-24-2008, 03:35 AM
  4. rapid travel
    By iccirvr in forum Mach Mill
    Last Post: 05-20-2008, 05:10 AM
  5. Int 412 shuts off on rapid Z axis travel
    By Jurek in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2007, 04:55 AM
