584,817 active members*
4,660 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > 1990 Partner IV and Centurion IV Problem!
    Aug 2010
    I am looking at a parnter IV that the battery backup has died. Looking for info on resting the parameters? Is it hard? Can I do it with a PC? Does anyone have the parameters?
    Mar 2005
    171
    I have the parameters on paper and on my pc. It's very easy. Email at [email protected] and I can help you out.
    Your battery for holding the parameters in memory is found at McMaster-Carr
    part # 6951K12 3.6volt "D" size.
    Aug 2010
    Ok so I bought a Machine got it all put together. But now I have an Error 4 that will not clear... Any Help!!!?
    Mar 2005
    171
    The ERROR 4 is telling you that your servo drives are not activated, ie.
    turned on.
    I'm assuming you solved your parameter(s) problem? So you turn on the machine
    and it wants to GRID (go home on all 3 axis). You must depress the RESET button to turn on the servos. Once the servos are on you can grid the machine.
    If the servos are not on you will get an ERROR 4, whenever you try axis movement of any kind, ie. GRID, MDI, JOG, Handwheel.
    If the servos don't turn on, you have another problem which could be a number of things, and I'll need more info.
    Ben
  1. partner 0-5 centurion 5(homing problem)
    By irtaza in forum Milltronics
    Last Post: 09-27-2022, 10:22 PM
  2. Partner IV with Centurion IV controller - Operational
    By SpeedMetal in forum Milltronics
    Last Post: 02-01-2011, 10:29 PM
  3. Partner IV w/Centurion V Problems
    By KurtsKustom in forum Milltronics
    Last Post: 05-10-2008, 01:53 AM
  4. Partner 1, Centurion 5 upgrade problem
    By lotsa luck in forum Milltronics
    Last Post: 12-21-2007, 04:11 AM
  5. Partner centurion 1 control
    By jas6142 in forum Milltronics
    Last Post: 12-04-2006, 05:49 PM
