585,605 active members*
3,263 visitors online*
    Aug 2010
    ARTCAM MMG. TO NCSTUDIO
    our new Jcut router is alive but can't get it to do much..In artcam 7, I can't find a MMG. file extention to save and open in ncstudio 5.4..China gives me no help..I know that it needs G code to run the table how do I get this MMG. ext?? Any help would be great!
    Apr 2007
    8082
    Quote Originally Posted by Ironmaster View Post
    You'll come closer to getting your answer over in the ArtCam Pro forum
    here. This is a build log forum.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jun 2008
    11
    Why not, I use MMG to save toolpath in artcam 7 as well as other versions
    So there is option availabel to save toolpath in MMG(modelmaster)
    santosh
    INDIA
    Aug 2010
    JCUT Router
    I have found how to save .mmg files in Artcam 7. That works and I can open and cut with NcStudio.
    Now I am importing muliple items to a model which I have set up to be the size of my material. It seems to take a long time to import each item and after I place them on my sheet, I nest them and for some reason, I get objects on to of objects. Any help? Also, I can just save the toolpath without nesting as a mmg and that works.
    We also have a plasma cutter that uses Pronest and that works well. Anyone have any experience with Pronest and a CNC router?
  1. problem with ncstudio and cnc router
    By djdre in forum Commercial CNC Wood Routers
    Last Post: 04-04-2023, 11:16 AM
  2. NcStudio help needed.
    By theforce in forum Commercial CNC Wood Routers
    Last Post: 02-23-2022, 01:49 PM
  3. problems Chinise Router NcStudio
    By frad8 in forum Chinese Machines
    Last Post: 05-31-2021, 08:34 PM
  4. Ncstudio Upgraded Version V5.5.60 (ENGLISH)
    By EXLASer in forum Commercial CNC Wood Routers
    Last Post: 04-25-2019, 07:15 AM
  5. PostProcesador de artcam para ncstudio
    By vectorizate in forum Spanish
    Last Post: 07-14-2010, 04:40 AM
