585,974 active members*
4,384 visitors online*
Results 1 to 6 of 6
    Jun 2006
    43
    PMI AXA servo amps
    Hi all,
    anyone out there have experience with, or opinions on PMI axa-180-10-20 amps.
    I am looking at retrofitting a mill with these amps, they are 1980's vintage and I wonder if I should just replace them with new amps (I need the machine to be reliable) any suggestions for a good reliable replacement amp.
    Dave
    24221
    If these are DC brushed, look at Advanced Motion Controls.
    Depends what controller you are going to use.
    Al.
    Albert E.
    Sep 2010
    1765
    obsolete. we dont even have any left and we specialize in keeping the old PMI and Kollmorgen drives in stock here. Can send u manual if you want on them. AMC is prob best choice for low cost replacement. If they work you might just keep using them.
    They were used on LOW INDUCTANCE motors (pankace style) with <50uH and even AMC needs inductor added in series to run those motors so be careful; most folks even as AMC wont realize this and it can blow up the new amc drive....
    Jun 2006
    43
    Thanks Mike, this info can help me avoid a possibly expensive learning curve.
    I will re-use the amps, I would like to give the PCB's a good clean, any advice on products and methods ?
    Dave
    Sep 2010
    1765
    I can't be made responsible if damage them following my hints here but....
    We clean drive pcb's with plain old 100% alcohol and a scrub brush. sometimes 409 cleaner too but if you leave it damp with water you will likely blow it up when powered up!
    Alcahol and brush is best bet if you must clean them and then let them dry a long time! be gentle to not break off any parts - u might want to make use of your nice camera and take a few pictures of the pcb BEFORE cleaning so you can compare afterwards if it stops working to see if you broke a part....
    Good luck!
    24221
    Also there is items like M.G. Chemicals Cleaner-Degreaser for the very reason, the likes of DigiKey or Newark etc should be able to supply.
    Al.
    Albert E.
  1. Aerotech amps and servo
    By HONDAPETE in forum Servo Motors / Drives
    Last Post: 01-05-2010, 10:50 AM
  2. Hurco Fet Servo amps
    By DonnieET in forum HURCO
    Last Post: 01-27-2009, 05:14 AM
  3. Wanted A/C servo amps & motors
    By Bap in forum Servo Motors / Drives
    Last Post: 05-13-2007, 06:23 PM
  4. older Brush Servo amps
    By miljnor in forum Haas Mills
    Last Post: 02-19-2006, 04:06 AM
  5. DC servo amps
    By converterk in forum CamSoft Products
    Last Post: 12-22-2003, 06:09 AM
