585,967 active members*
4,116 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > How are you keeping your Mill area clean?
Results 1 to 19 of 19
    Nov 2008
    164
    Post your Pictures of how you are keeping the mess under control with your mills.
    I have curly chips EVERYWHERE in my shop and I think my wife is about to strangle me (Alum chips throughout the house...:nono:
    Feb 2004
    1311
    My mill is in my basement work shop. I keep an old pair of shoes in the shop and I put them on first thing when I enter and take them off when I leave. That really cuts down on tracking chips! Then, I actually run a shop vac while i cut on the mill or lathe. I don't have a coolant system so this works great. Other than that, I sweep after every session wirh a dust broom and pan.
    Cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Feb 2006
    57
    I use old carpets on the floor of my shop especially on the path into the house. Its really amazing the difference that they make. Plus just alot of sweeping the floor. I also use cardboard boxes for the chips beleive it or not for storing them. I also made a fence around the table about eight inches high. It contains alot of chips and spray from the coolant.
    Aug 2009
    986
    My washer and dryer are in the garage with all my tools. After a session, I strip down in the garage and put the clothes straight into the washer, then either grab clean clothes from the dryer or just head in and hit the shower.
    Hey, you asked.
    And yes, I live alone and have an attached garage.
    Dec 2007
    362
    Quote Originally Posted by TXFred View Post
    Hey, you asked.
    Do you do this because you live alone or is it why you live alone?
    I also live alone and try my best to keep the swarf out of the carpet - I'm the one who has to clean it up. An old door mat near the exit to the workshop does the trick.
    Regards
    Geoff
    Aug 2009
    899
    Get a bench brush so sweep the chips into the floor, then use a shop-vac to suck them all up, but then again I'm not running coolant on my 7x10 mini lathe or my X2. The RF45 will be in an enclosure with a drain at the bottom for all chips and coolant to flow into a bin.
    Mar 2005
    305
    My kids call the chips "pokeys" my house. Best solution I found is an enclosure for the mill and lots of sweeping for the lathe. I have a pair of shop shoes and do not wear them in the house. Change at the door.
    Oct 2005
    2392
    My work area is usually kept clean using Work Impeding Female Extraction procedure.
    Jun 2010
    I use a lab coat separate shoes to keep the chips off me
    Sweep up everything into the corner with a brush
    I have concrete floor where the lathe and mill are and carpet coming out of the garage
    An air gun to blow the chips off me and to clean the floor
    Jun 2008
    614
    Quote Originally Posted by RomanLini View Post
    thats what keeps my area dirty...as soon as i start to work she stomps on the floor or calls my cell phone :nono:
    http://www.g0704.blogspot.com/
    Feb 2007
    664
    works for me
    Mar 2007
    534
    I have never told wifey that swarf is death to carpets. It gets into the pile it slowly saws it apart. If she ever finds out my workshop days are over (nuts)
    Aug 2006
    1602
    Never mind carpets - chips and curly hair are a nightmare. Is that a gray hair - no it's 6082 :rainfro:
    I find a dust pan and brush are better than a vac - but you really need to wear saftey glasses while brushing as it's very easy to flick chips up into your face.
    Nov 2008
    164
    So I came up with a working idea last night and it worked GREAT. I made up a Good version today. I used plastic strip curtain and some Rare earth Magnets from Lee Valley. Cost me $30 for the magnets.
    Attached Thumbnails Attached Thumbnails IMG_1654.jpg   IMG_1652.jpg   IMG_1653.jpg   IMG_1651.jpg
    Aug 2009
    899
    That is one large vac hose, where did you get the flex hose like that?
    Nov 2008
    164
    Loc-Line product
    http://www.loc-line.com/products/vacuum/vacuum.html
    Its reasonable for price. I got most of it from Lee Valley but the cone end was from another Loc-Line supplier.
    Mar 2008
    331
    I just built an enclosure around mine.
    I plan on doing the same with my little mill soon also, along with a vacuum.
    rudykeppler Guest
    Re: How are you keeping your Mill area clean?
    Using a parallel keeper in your vise like ParaKeep brand lets you blow out chips and coolant without it spraying back all over you.
    rudykeppler Guest
    Using a ParaKeep in your vise lets you blow chips out the side without spraying them all over the place. You can get them at Parakeep.net. Keeps your vise way neater.
  1. Keeping the Syil X3 Mill Cool
    By Chrisjh in forum Syil Products
    Last Post: 03-03-2010, 10:13 AM
  2. Keeping Coolant Clean?
    By donl517 in forum Fadal
    Last Post: 02-01-2010, 10:31 PM
  3. keeping rails clean
    By HMD in forum DynaTorch
    Last Post: 10-14-2007, 12:46 AM
  4. Question of keeping Ball Screws Clean
    By widgitmaster in forum DIY CNC Router Table Machines
    Last Post: 10-06-2005, 02:16 AM
  5. Keeping the 'puter clean
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 01-01-2004, 12:30 AM
