585,668 active members*
3,982 visitors online*
    Mar 2006
    255
    Reducing Gcode for simultation 4 axis
    Hi
    I was just playing around with the 4 axis post. And one thing I did notice was the length of code.
    What I did was just use the 5axis operation, (parallel to curve) and few others on a ball shape (ish) around the 4th axis, using a lollipop cutter. When I output the gcode, its always using the @move_5x and @line_5x. Which makes it generate a hell of alot of code.
    I was wondering, whether it is possible to make the output use one of the @arc procedures or similar, or is this just going to kill the system during calculation, and so has not been developed?
    Maybe an option in solidcam before calculation, but I can't locate it. I was hoping it would be something similar to using cartezian, maybe....
    Mar 2006
    255
    I'm guessing that is a no.
    Thought I'd ask
    Feb 2006
    992
    I asked this question before and ..... up to date the answer is still NO.
    The best way to learn is trial error.
    Oct 2007
    499
    I am afraid not. I keep waiting for SolidCAM to put the technology in for NURBS and the (if your control is up to it) complex 4 and 5 axis moves would be reduced to one line of code for one line of toolpath such as you suggest.
    Mind you I have just had a thought, is there anything in the MAC to say whether arcs are allowed in 4th axis? I can't remember and I am not at my desk right now.
  1. 4th-Axis GCode Programming
    By twehr in forum G-Code Programing
    Last Post: 02-19-2023, 11:02 AM
  2. Way to take gcode for one axis and mirror it for another axis?
    By genestapp in forum Uncategorised CAM Discussion
    Last Post: 10-09-2010, 04:14 PM
  3. Replies: 3
    Last Post: 04-10-2010, 01:23 AM
  4. 4th gcode axis problem
    By fabconv in forum Visual Mill
    Last Post: 08-29-2009, 01:39 PM
  5. What is the gcode to ref 1 axis home after
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-07-2008, 11:18 PM
