585,760 active members*
3,689 visitors online*
IndustryArena Forum > CAM Software > UG NX > NX6 to CNC file transfer
    Mar 2009
    43
    Question NX6 to CNC file transfer
    Hi friends, i want to know if it is possible to transfer my cnc program directly from NX6 to cnc ? Now i am using Winpcin. if it is possible means kindly explain me the procedure.
    May 2010
    yes it is possible through the pcin and so set up a Rs232 cable 25 pins of both
    sides according to the manual programming of the machine
    and soon after creating this cable to configure the ports from the micro to the machine
    so you managed to quietly transmit programs via dnc
    ANDRÉ LUIS DO NASCIMENTO
    SPECIALIST CAM APPLICATIONS MULTI AXIS / IS&V (NX)
    Mar 2009
    43
    Thank you friend. pcin, you are meaning Winpcin? because now i am using SIEMENS Winpcin. but i want to transfer my NC programs from NX6 to CNC. because some friends told me that some camsoftwares having these facilities.
    Regards,
    Keyan
    Re: NX6 to CNC file transfer
    You can use CNC Data Transfer from Google Play store, if you need transfer data from your Android Device to CNC.
  1. Transfer file
    By Master Miller in forum Fanuc
    Last Post: 03-20-2011, 08:45 AM
  2. File transfer
    By Barrett in forum Okuma
    Last Post: 08-16-2010, 04:53 PM
  3. file transfer
    By valleyron in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-16-2008, 10:29 PM
  4. File Transfer
    By roninB4 in forum Community Club House
    Last Post: 08-27-2006, 05:05 PM
  5. file transfer
    By axis overtravel in forum Fadal
    Last Post: 01-27-2006, 04:55 AM
