585,996 active members*
4,366 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Problem with turning arcs in Flashcut
Results 1 to 3 of 3
    Aug 2007
    4
    I have upgraded my lathe module to version 10 and for some reason every arc that I produce G-code and then open in Flashcut, turns into an arc-complement/concave radius. Is there a setting that needs to be fixed?
    Thanks!
    Flashcut arcs - v10
    You need a post upgrade / modification.
    Send me a copy of your Flashcut post and I will implement mods.
    michael
    Dolphin CAD CAM Systems Ltd
    Dolphin CAD CAM Ltd
    flashcut upgrade
    michael
    Dolphin CAD CAM Ltd
  1. Autocad to Mach3 problem with arcs
    By LTP in forum Mach Lathe
    Last Post: 07-25-2010, 03:08 PM
  2. Huge Problem with Turning Arcs HELP
    By Cartierusm in forum Dolphin CAD/CAM
    Last Post: 06-11-2009, 01:40 AM
  3. Fanuc 10M feed problem in arcs
    By AMEG CNC in forum Fanuc
    Last Post: 02-07-2007, 12:58 PM
  4. dxf file import problem with Flashcut CNC
    By oakcnc in forum Uncategorised CAM Discussion
    Last Post: 01-17-2007, 05:06 PM
  5. lines-arcs vs spline problem
    By metlcutr55 in forum Uncategorised CAM Discussion
    Last Post: 07-07-2006, 04:16 PM
