585,987 active members*
4,436 visitors online*
    Aug 2010
    Purchasing larger qtys of screwdriver bits
    I'm not sure if this is the right forum for this, but my company is looking to buy larger quantities of 1/4" hex insert bits, the 1" long type, commonly used in screwdrivers. A whole mix of different head styles- Phillips, Pozi, hex, slotted, etc.
    Typically it looks like you need to be buying several thousand bits before you go directly to most manufacturers. We're looking at buying a couple thousand with each order. Does anybody know of a good source for these, where you can get wholesale type discounts?
    And no- we're not planning on machining these ourselves!
    p.s. any suggestions for other forums for info would be appreciated too
    Jul 2007
    1602
    I have seen some in "candy jars" at Home Depot. Check them out, perhaps you can get supplier info from the jars.
    bob
    Feb 2007
    4553
    Post
    Ingear,
    Blatts Bargains on e-Bay sells them cheaper than anyone.
    http://tinyurl.com/39coh6j
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2006
    58
    You might try contacting Apex and find a rep/distributor.
    http://www.coopertools.com/catalog_p...1=10&catlan=EN
    varonicaleon Guest
    Thanks for sharing this post with us I really want to know about this.
  1. Larger VFD Than Required?
    By Willyb in forum Phase Converters
    Last Post: 05-13-2009, 01:36 AM
  2. Larger Offsets for the 5T
    By Paul Pippenger in forum Fanuc
    Last Post: 03-15-2009, 05:55 PM
  3. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  4. If you must play with nuclear fusion, use a big enough screwdriver
    By Al_The_Man in forum Community Club House
    Last Post: 09-05-2008, 10:31 PM
  5. Broaching screwdriver slots on lathe
    By laka in forum MetalWork Discussion
    Last Post: 08-15-2008, 08:53 PM
