585,933 active members*
3,644 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560 (HY-TB3DV-M) limit switch connector?
Page 1 of 2 12
Results 1 to 20 of 27
    Aug 2010
    Just got my CNC moving about, and now I can see that having limit switches hooked up would be nice. Unfortunately the limit switch connector is some kind of funky little polarized 5 pin thing. Does anyone know what it is and where I can get the matching part?
    24221
    That number does not show up, what make is it? or post a picture.
    Al.
    Albert E.
    Aug 2010
    Al.
    It's this: http://fozztexx.com/CNC/HY-TB3DV-M_3Axis_Driver.pdf
    Jan 2007
    146
    Is it sort of like a floppy power connector, or does it have thin pins in it spaced .100 apart?
    Aug 2010
    Quote Originally Posted by jschmitt View Post
    Definitely not a floppy connector, the pins are closer than .100.
    24221
    Your best bet is to measure the pin pitch and search the DigiKey catalogue.
    They have almost every type known to man!
    I would particularly at the Hirose style, they usually make miniature and micro-miniature type.
    It looks similar to the DF13 1.25mm pitch?
    Al.
    Albert E.
    Feb 2007
    4553
    Post
    Al,
    I believe it is a 2.5mm XH connector.
    Jeff...
    Attached Files Attached Files
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    24221
    Quote Originally Posted by jalessi View Post
    Al,
    Jeff...
    But the OP said it was much closer than .1" (2.5mm)?
    Al.
    Albert E.
    Feb 2007
    4553
    Post
    Al,
    Not trying to be a smart a$$ however 2.54mm is .09999749
    Is the user measuring the gap between the pins or the center to center dimension?
    Sorry for the incomplete reply,
    Jeff...
    May 2010
    327
    I have an extra one I'll mail you if you give me your address...
    WW
    Feb 2007
    4553
    WW,
    That is very generous, can you post a good picture of the cable?
    Jeff...
    May 2010
    327
    Jeff -
    don't have one at the moment...but I have the exact board you posted the link to, and it came with a cable (I fried the board, though)...
    "I believe it is a 2.5mm XH connector."
    I have to agree.
    WW
    24221
    Al,
    Jeff...
    Maybe, but if you are catalogue shopping for connectors they are invariably listed as .1" (2.5mm) or 2.5mm (.1") pitch.
    Al.
    Albert E.
    Aug 2010
    Ok I measured the pin spacing and they are 2mm on center. I also took a couple of pictures:
    http://fozztexx.com/CNC/IMG_3080.JPG
    http://fozztexx.com/CNC/IMG_3081.JPG
    May 2010
    327
    Yep - I have 1 of those exact connectors, with about a 6" lead (5 wires), for no more than the effort of PM'ing your mailing address to me. I'll drop in the USPS tomorrow...
    WW
    Aug 2010
    Quote Originally Posted by wildwhl View Post
    WW
    Thanks so much for the cable! It fits perfectly.
    Now that I have the cable I was able to figure out what the connector is. In case anyone else stumbles on this thread, it's a JST PHR-5 housing. Here's the data sheet: http://www.jst-mfg.com/product/pdf/eng/ePH.pdf
    Feb 2009
    9
    Auto tool zero / input pins / TB6560
    Can I use these pins for Mach3 auto tool zeroing?
    Aug 2010
    Quote Originally Posted by karri View Post
    If you have the switches wired up to them.
    Feb 2009
    9
    I have a wire from copper pcb connected to GND. The other wire from the alligator clip is connected to pin 13.
    In ports and pins input I configure the probe input to pin 13 active high or low?
    Aug 2010
    I don't use Mach3, I use EMC2/Axis. You should probably go ask on the Mach3 forum.
Page 1 of 2 12
  1. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  2. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-17-2008, 12:56 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
