585,991 active members*
4,574 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > unable to drive stepper motor
    Dec 2006
    130
    I have a problem with my vexta stepper motor. Using the PIC16f877, I could run the motor. But using the keyence kv-40DR I am unable to do so. The motor moves forward and backwards, kind of weird movement.
    The programming is almost the same. Same pulse inputs and etc. I have tried with different driver and even motor. But same results.
    The only difference is the PIC16f877 is a transistor relay and the kv-40DR is a normal relay PLC.
    Is that the cause of the problem?
    Jan 2006
    738
    Normal relays tend to have contact bounce. When the armature of the relay moves to close the contacts, the contacts actually strike and bounce making multiple very short connections before connecting firmly. This would not be a problem for controling a solinoid valve or a light. The logic inputs of a stepper motor driver will see the multiple pulses and act erraticly.
    Steve
    Dec 2006
    130
    Quote Originally Posted by vger View Post
    Steve
    Thanks Steve,
    Finally I am enlighten on this weird issue.
  1. 4A stepper motor drive
    By mithunraj in forum Stepper Motors / Drives
    Last Post: 04-17-2008, 08:15 AM
  2. ?? How to drive the Stepper Motor
    By eein in forum CNC Machine Related Electronics
    Last Post: 08-30-2007, 02:40 AM
  3. 3 axis stepper motor drive
    By Paul V in forum Shopmaster/Shoptask
    Last Post: 02-24-2007, 09:34 PM
  4. drive a stepper motor by L6208
    By Jo_Jo in forum Stepper Motors / Drives
    Last Post: 06-02-2006, 04:29 PM
  5. drive a stepper motor
    Last Post: 09-08-2005, 07:41 AM
