I use FlashCut CNC ver. 2.0.9 to cut sheet metal using a Hypotherm Plasma Cutter. I have started getting an error intermittently that states I have lost the connection with the signal generator, try turning off and on to reset/check connections etc. I have been unable to pinpoint where the problem is, but suspect it is in the Flashcut Signal Generator Box. I ordered a new 9 pin cable in the hope that the solution is that simple but have not received it yet. Has anyone else had this problem and can offer recommendations to fix?
