509,955 active members
4,185 visitors online
Page 1 of 6 123
Results 1 to 12 of 61
    Registered
    Feb 2006
    190
    Dry Machine Aluminum?
    I've been pouring over Bob Warfield's wonderful site www.cnccookbook.com for the last week. He talks about dry machining aluminum, but it seems his definition of dry is "not flood". I'd like to machine aluminum actually dry and wonder how I should change my feeds and speeds in G-Wizard? From reading Bob's post it seems like I should alter my SFM, but by how much when completely dry is not spelled out.
    I will be taking 0.05 WOC, .1875" DOC passes through 6061 with a 3 flute 3/8" endmill made for Aluminum at my roughing stage. G-Wizard suggests 49 IPM @2000RPM on my X3 mill. Any suggestions for a better IPM or DOC (WOC is fixed in my setup)? Can I really run that fast dry?
    Attached is a picture of my project for this weekend:
    Registered
    Dec 2009
    1416
    You gotta show that off after this weekend!! I'm wanting badly to do an AR-10 myself. Gonna be one of my CNC projects when I get it going.
    Registered
    Apr 2004
    52
    In my experience the 2 biggest problems with cutting aluminum without coolant are buildup on the cutting edge and clearing chips. You need to use some type of lubricant to prevent the buildup of aluminum on the cutting edge. I have used small amounts of WD40 succesfully. You also need to remove the chips from the cutting path as they will get pushed through the cut again and mar the surface finish. You could use a vacuum to remove the chips and then small amounts of wd40 sprayed on to keet the edge lubricated. Cooling really isn't that big of a problem on aluminum unless you want to cut at very high spindle speeds.
    Registered
    Dec 2006
    222
    What you describe above is EXACTLY how I do most of my aluminum cutting - a few squirts of WD-40 at the start to the process and vacuum up the chips every few minutes. You do get some roughness on the edges if you don't vacuum frequently enough but for quick stuff this has worked really well for me on the X2.
    -Mike
    Registered
    Jun 2009
    195
    To give you an idea of what you can get away with on 6061, I have a flashcut 6500 and found I could take full with of cut 0.035 " doc at 15,000 rpm @ 35 ipm with a 2fl 1/4" carbide end mill I picked up at homedepot .
    If you want to machine dry 7075 works with no chips sticking to the part like 6061
    Registered
    Jun 2008
    614
    Wait...HD sells endmills?!?
    wow i will have to check it out...
    http://www.g0704.blogspot.com/
    Registered
    Dec 2006
    222
    A router bit rather than an endmill I suspect
    Registered
    Jun 2008
    614
    Quote Originally Posted by webgeek View Post
    I kinda thought the same... i really wish i had a local vendor I could walk in and buy machine tools...but seems theres is not much in my neck of the woods...I really hate internet orders...
    Registered
    Jun 2009
    195
    ya it is a 2 fl up sprial router bit . I didn't want to wait for an order from duramill other wise I would have used that . point is I used junk tooling at high rpm and no melted tool in work pice !
    Gold Member
    Feb 2006
    7087
    For dry cutting, keep the same SFPM as for any other cutting. Calculate feedrate based on the manufacturers maximum recommended chipload (typically on the order of 0.004-0.005" for a 1/2" HSS endmill), and do a shallow cut. Go progressively deeper until either the spindle starts to bog down, vibration gets excessive, or the tool starts clogging. I can cut 0.125" deep, 1/2" slotting, at over 30 IPM with HSS. If you get clogging, INCREASE the feedrate. The tool gets hot when you feed too slow. When you feed fast, the chips will come off VERY hot, and the tool will stay cool, until you get into pretty deep cuts.
    G-Wizard does an excellent job of calculating the best-case cuts you can do. I would start with its recommendation, but a shallower cut, then sneak up on the final depth you want, to make sure the machine can handle it. This will avoid tool breakage.
    Regards,
    Ray L.
    Registered
    Feb 2006
    190
    Thanks for the suggestions (especially Ray). I'll start off with running at the full speed that GWizard says I should run, but use 75% of the cut depth I calculated with. If that goes well, I'll push up the cut depth and see how things go. Thanks!
    Registered
    Feb 2010
    Quote Originally Posted by Kingjamez View Post
    For my CNC machine, I found I had to drastically cut the cut depth when dry machining aluminum. I broke 8 1/4" HSS end mills finding the approximate ratio and debugging my own issues. make your cuts really light. And dont walk away if you aren't clearing chips. As the cuts got deeper they caused a lot of heat to condense on the cutter. As the bit heats up it can still dig and break. I ran a hose to my air compressor and it did wonders, but my "flood coolant" system is ready and can't wait to see how much more/smoother I can cut or how much longer I can make my end mills last.
Page 1 of 6 123
  1. My machine is cutting aluminum!!!!
    By ilya in forum DIY CNC Router Table Machines
    Last Post: 09-17-2009, 07:14 AM
  2. Spindle that can machine aluminum
    By Dman65 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2009, 04:28 AM
  3. I am looking for cad files for an all aluminum machine
    By runinbymdnt in forum DIY CNC Router Table Machines
    Last Post: 11-04-2006, 05:14 PM
  4. new machine, aluminum or steel ?
    By max_imum2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2006, 02:29 PM
  5. MDF Machine - Cut Aluminum?
    By JavaDog in forum DIY CNC Router Table Machines
    Last Post: 11-10-2004, 08:05 PM
