Anyone have a good source for the lube metering unit?
Tom
Tom
TarHeelTom
This is one of the places you can get them
http://www.internationalscrew.com/pa..._injectors.htm
Mactec54
Best to replace them all and flush the lines out, also take the pump apart and clean the reservoir, the oil gets gummy after many years use.
Al.
Albert E.
Here is another.
http://www.devcocorp.com/american/bijurmeters.htm
The Bijur are about $20 and they have an aftermarket part for about $17.
Darek
We have taken the pump completely apart and cleaned it. Working fine as a manual pump now.
There was a ton of gunk in the bottom of the tank.
We do plan to take off all the lines and flush them, but got to get oil past the tee first.
Tom
