585,759 active members*
3,895 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > sellecting bit to cut laminated paper
    Aug 2010
    currently using 1/4" compression bit 2 spiral to cut 1/2" corrugated paper.
    need smooth finish top and bottom. Would like to make cut smaller ie 3/16"
    Any suggestions? Most compression bits I have found are no smaller than
    1/4" dia 1/4 shank and 7/8" deep. Any problems with this idea? Feed rate
    is 750
    Onsrud makes a 3/16" compression, but it's a single flute, so may slow you down a bit. They may make a two flute, but i didn't have time to look.
    http://www.toolsxp.com/Onsrud-Cutter...s-60-100SE.asp
  1. Laminated Beam
    By lgroulx200 in forum DIY CNC Router Table Machines
    Last Post: 10-24-2006, 03:43 AM
  2. square laminated or toroid transformer?
    By freak_brain in forum CNC Machine Related Electronics
    Last Post: 07-10-2005, 01:12 AM
  3. paper jig
    By David454 in forum Uncategorised CAM Discussion
    Last Post: 04-18-2003, 08:59 PM
