585,727 active members*
3,930 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Using multiple work offsets in MC
Results 1 to 7 of 7
    Mar 2007
    215
    Hi guys,
    I have what I am hoping is a very simple problem with using multiple work offsets (g54-g58) in MC. I currently generate a tool path and then have to copy that tool path 4 times and individually change the offset #(0,1,2,3) in the WCS tab for each tool path. There has got to be an easier, less time consuming way to achieve this.
    -CM
    Oh- I am currently using MC X4
    Dec 2008
    3109
    Yep,
    Try the Transform,
    You should end up with 1 operation and 3 repeats at the same place,
    modifying the 1st operation carries automatically over to the other 3 paths
    Mar 2007
    215
    Thanks for the reply. I tried using transform. Maybe I don't understand the concept behind this. If I leave the type on translate the work offset numbering options are grayed out. I'm assuming I want to use translate and not rotate or mirror. I've tried to find info on this on the MC help menu but can't.. Any suggestions?
    Dec 2008
    3109
    -Select the operations you want transformed
    -Select the Type of transform (trans, rotate, mirror)(Tplane origin ON for offset # output)
    -Method ( toolplane=offset numbers come into play, Co-ord=adds a distance to the NC output values)
    -group NCI ( machining sequence if 2 or more ops or tools )(order=finish 1 part in op order before moving to the next, type=fininh each op across all parts before moving to the next op )
    Copy source ops =ON
    Disable=depends where your source ops are placed
    Work offset - assign new start=1, Inc=1 ( your start # may be 54 )
    Mar 2007
    215
    Thanks superman, I think I got it now. much appreciated!
    Dec 2008
    3109
    By the way, there is another method instead of transforming
    simple to implement for single view parts
    is copy to the WCS 3 times and change the work offset number for each
    pros
    -you can see and plan exactly the sequences you want
    -view this method as the step before understanding transform
    cons
    -lots and lots of ops
    -greater chance of errors ( modify a path but not all paths or the wrong one )
    Mar 2007
    215
    Thanks for the info. I can't believe this wasn't discussed in the in program help guide or the manual. I must have missed it!
  1. Multiple Work Offsets
    By 9 1/2 in forum Mastercam
    Last Post: 11-15-2009, 11:28 PM
  2. multiple work offsets in MCX
    By bob1112 in forum Mastercam
    Last Post: 10-01-2008, 02:17 PM
  3. Multiple Work Offsets X3
    By timmydabull in forum Mastercam
    Last Post: 08-28-2008, 06:54 PM
  4. Multiple Work Offsets
    By PinMan in forum BobCad-Cam
    Last Post: 06-06-2008, 10:41 PM
  5. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
