585,727 active members*
4,000 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Combo Lathe/Mill machines. OK to buy or buy separate?
Page 1 of 2 12
Results 1 to 20 of 21
    Aug 2010
    What are the pros and cons of having an 'all in one' lathe/mill?
    I have several other questions that I will post in other threads but wanted to get this one out of the way. I'm looking at some mini combos at the moment. Thanks in advance.
    Feb 2010
    Most who buy a combo express disappointment.
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
    Dec 2008
    21
    A good analysis on this subject here
    http://www.tormach.com/document_libr...gnAnalysis.pdf
    Aug 2010
    Thanks for the responses. *groans at the PDF, but starts to read*
    I checked out a book at the library on metalworking as well. I'm hoping I can fully understand which machine (lathe or mill) will accomplish what I ask it to do and hopefully... eventually have enough imagination and brains to own both machines.
    Nov 2005
    264
    basically, a combo machine is neither a good lathe nor a good mill.
    if you are just getting started in machining and dont want to spend alot, look for a used X2. There is a huge amount of support and parts available, and it is big enough to get your feet wet. For a lathe, refer to the mini lathe forum, but I would imagine any of the import 7x lathes would be perfect for starting out.
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
    Feb 2009
    6028
    Personally I think they are a PIA. Always tearing down one set up to do the other.
    Aug 2010
    Quote Originally Posted by underthetire View Post
    I "upgraded" from a separate mini mill and mini lathe for my first home shop setup years ago, and this was my experience. The hassle of switching from lathe to mill operations and back was such that it actually kept me from doing some jobs. (The lathe compound is also the X-Y for the mill.)
    What was interesting was that the lathe had a huge swing to bed, like 14 inches, but only 3 inch swing to compound. And since the compound doubled as the X-Y table for the mill it was too large and clumsy for lathe operations but way too small for mill operations.
    I think I paid $1,400 for the combo machine, which would be roughly the same cost for a Grizzly 9x20 and mini mill shipped to your door.
    May 2010
    327
    I have a combo machine, and it was a good way to get started. I am ready to move it out, and get a decent lathe now. Honestly, I'd recommend a mill and a lathe (2 machines) if you can swing it. It is a total PITA to tear down and switch between lathe/mill functions. Mine is the HF version - and the work envelope is very small when milling, unless you remove the lathe chuck.
    Bill
    Aug 2010
    I appreciate all the responses so far everyone. I'm going to look for a used X2 as suggested above. (A five minute search hasn't yielded any for sale so far though!)
    Feb 2010
    For the lathe, I would start with a 9 x 20 (aka 9 x 19) or larger. If you can only buy one of the two to start with, start with a lathe. 10 x 22 should be a sweet little lathe. You can do a lot with a 7 x. Many have and so have I, but it is not rigid, and many of them start out with problems when new. Not much capacity.
    http://www.grizzly.com/products/cate...spx?key=460000
    If your plans do not include CNC, I would check out used American machines, but that's a different story.
    Aug 2010
    Thanks. I very much want to migrate to CNC at some point. I'm falling in love with the possibilities!!
    Based on my limited knowledge and what I've read and want to do-- I think I'll take the advice and go separate. I'm going to start with a mill. I couldn't find a used X2, but I think this device new should be adequate for what I'm wanting to do (machine parts for small wind turbine generator)
    This website has a good listing of some of the parts I want to machine and here is the machine I believe will do the 7 inch diameters by 3/8 inches thick (MicroLux High-Precision Heavy-Duty MT3 Miniature Milling Machine) http://www.micromark.com/MICROLUX-BE...MILL,8102.html
    Some of the parts: http://www.windstuffnow.com/main/builders_corner.htm (I would have linked the pics but I wasn't sure about copyright etc..) Mind you his design is an idea of what I want to do.
    Or am I totally wrong and a lathe would be better for this type of work?
    Thanks for your time everyone!
    May 2010
    327
    Uh oh, a windpower guy
    A lot of what you need to build there (the builders corner link) might be doable simply on a drill press with some patience. Depends on the material you're working in. I, too, have a couple of wind-power projects on the back burner - the next being a 5 *wing* Ropatec style VAWT, 3' high, 6" chord wings. The mini mill and lathe will be put to work building the rotating axis and bearing supports, as well as the arms, wing mounts, etc.
    You mention 7" diameters - if you're looking for a mill that can cut a 7" circle, if you will, then both the x and y travels need to be at least that much (actually more, to account for the diameter of the milling tool).
    Guess I'm not sure what your question is at this point...but happy to help where I can.
    Bill
    edit: I suppose you could cut the 7" disc on an x2 - would require multiple setups and care.
    Aug 2010
    Thanks wildwhl. I appreciate the tips and insight. I'm just hoping that a mill alone can do the stuff on that link above. Gotta a lot of learnin' to do....
    May 2010
    327
    Mill is a darn useful tool - and with some thought can do many, many things. On the other hand, I don't know how I made it until 40 before owning a lathe. I use it several times a week...the CNC x2 does more complex work, but heck, the lathe - if I don't have the right length bolt - few minutes later shortened and all cleaned up (not the old grinder/hacksaw method). I'm happy I have both
    WW
    Aug 2010
    What are your thoughts on that Microlux mini mill? http://www.micromark.com/MICROLUX-BE...MILL,8102.html
    I'm open to suggestions. ~$500.00 range seems reasonable to start for me.. and another $500 probably for "stuff" (from what I've read here, tools etc.. will cost a buck or three!)
    Thanks!
    Nov 2005
    264
    great place to start for the X2 is http://www.hossmachine.info/cnc_conversion.html
    Jun 2003
    232
    Parkham,
    I had a Harbor Freight X2 which I recently sold as I am looking to purchase a G0704 as described here:http://www.grizzly.com/products/Dril...th-Stand/G0704.
    The G0704 is much sturdier and has a much bigger work envelope than the X2. Also, you can do some lathe operations on a mill especially if you set up a fourth axis.
    Feb 2010
    Quote Originally Posted by Parkham View Post
    Thanks!
    That's an x2, costs less elsewhere, HF etc...
    Dec 2007
    362
    You could start with something like the Grizzly G0516 and when changing setup from mill to lathe becomes a pain , move the mill off to a separate XY table from LMS.
    Regards
    Geoff
    May 2010
    327
    That's an option, too - though I think you could buy a lathe and mill from Grizzly for about the same money?
    Where does the OP live - maybe we can help find him something
    WW
Page 1 of 2 12
  1. lathe mill combo
    By lee heroux in forum Want To Buy...Need help!
    Last Post: 08-31-2009, 07:04 PM
  2. Mill/Lathe combo cnc?
    By JSU in forum Uncategorised MetalWorking Machines
    Last Post: 09-03-2006, 10:01 PM
  3. mill lathe combo
    By mysterious in forum Uncategorised MetalWorking Machines
    Last Post: 07-03-2005, 09:57 PM
  4. Thoughts on HF Combo Mill/Lathe
    By MisterB in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2005, 06:41 PM
