Hi all,
I'm not sure this is the right place to write this thread, so I hope an admin will move it, if posted wrong place.
I have read a bit in here from time to time, when I have had some problems. And a lot of times I have found the answer to my queries .
But this time I'm having trouble getting our "turning-table" to change the feed rate, when I need to turn it.
I'm using a YCM106A Vertical milling machine, with a Fanuc MXP-200i steering. And our "turning-table" is a Golden sun CNC-251R.
I can turn the table using this command:
M28;
G54 A180;
M27;
And it then turns with a feed rate of 1000mm/min. I would say that's it rapid speed, not feed.
So how do I get it to turn in feed rate instead?
CheeRS and greetings from Denmark
TheDane
