585,560 active members*
3,298 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 506 and 507 Over travel Alarm
    Aug 2008
    7
    hello gents,
    i'm installing a daewoo H50S with 16M Fanuc control, i have a 506 and 507 Over travel + and - in all axis at the same time it is impossible but that is what i have in the control could any one here give me some advices? what could i do?
    24220
    It usually means the 24vdc supply to the OT switches is missing, the switches are active low so no voltage is the same as open switch.
    Al.
    Albert E.
  1. miyano bnc 34 nc alarm reset over travel
    By Progress Nc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2013, 01:25 PM
  2. Alarm 317 Y over Travel Range?
    By Rocko1 in forum Haas Mills
    Last Post: 06-29-2012, 10:28 PM
  3. x over travel alarm at startup
    By metalmansteve in forum Fanuc
    Last Post: 02-25-2010, 09:23 AM
  4. Soft stop over travel alarm
    By kayleesdad in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2005, 01:27 PM
