585,974 active members*
4,338 visitors online*
    Apr 2005
    53
    Fanuc 15MA Time
    Can anyone tell me how to set the time or atleast where to look at in the manuals, and no, it is not listed under time (lol). Thank you. :cheers:
    24221
    You should find it under Settings Screen it shows the parts total, power on time etc with Date/time at the bottom, IIRC you have to be in MDI to change it, With Fanuc, you won't find it in a Logical place.
    BTW It is also possible to read the time through custom macro variable if you needed it.
    Al.
    Albert E.
    Apr 2005
    53
    Al...... You Are The Man!! :wee:
  1. Programming PLC on Fanuc 0M
    By MetLHead in forum Fanuc
    Last Post: 02-18-2019, 06:36 AM
  2. Fanuc 18i-M controller
    By Wjman in forum DNC Problems and Solutions
    Last Post: 10-01-2010, 06:02 PM
  3. Fanuc 3M DNC operation
    By max_c in forum Uncategorised MetalWorking Machines
    Last Post: 07-05-2010, 01:11 AM
  4. Fanuc motor ???
    By jevs in forum Servo Motors / Drives
    Last Post: 03-16-2005, 11:47 PM
  5. FANUC coding compatability??
    By m1911bldr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-24-2004, 11:10 PM
