585,741 active members*
4,951 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Start push buttons Biesse Rover 13 does`nt light
    Apr 2009
    5
    Goodmorning,
    I own a Biesse Rover 13 point to point router and after having problems with the electricity in my shop which are now, after one year (!) solved, I can start the working cycle till the moment where the front and side stops should go out. There is no green light on the two start push-buttons, also there will be no vacuum on the table, even if the vacuumpump is running.
    Are here experienced users of a Rover 13 or likewise machine who can help me out?
    Regards
    Christiaan
    Sep 2010
    Hi, I too have a rover 13 and I am having some problems but I think we just about have it fixed. The limit switches seem to be rather flakey so we are in the process of cleaning the ones we can and replacing the ones that are really bad. We are getting error 3 on the panel and can only run the machine if we bypass the switches all together. I am in need of a operators manual for the NC 400 for this machine so if anyone has a pdf of it please email it to me. [email protected]
    Nov 2009
    121
    hello Cristiian
    do you resolved your trobules?
    do you known Biesseworks
    we have finish training and installation for rover 13
    if you need something
    here i am,
    Dec 2007
    30
    Re: Start push buttons Biesse Rover 13 does`nt light
    Hello guys, does anyone know what type of servo motors uses the biesse rover 13 s cnc router?
    thanks in advance
    Dec 2005
    594
    Quote Originally Posted by alfonsonog View Post
    thanks in advance
    You need to open your own new topic for this. Your question does not fit with this topic.
  1. Replies: 2
    Last Post: 05-03-2013, 03:13 PM
  2. Automec CNC 300 push buttons
    By Mister NCT in forum Bending, Forging, Extrusion...
    Last Post: 04-04-2013, 12:42 AM
  3. Biesse Rover 346 start up problems!
    By num1040 in forum CNC Machining Centers
    Last Post: 02-06-2013, 04:48 AM
  4. Biesse Rover 22 Start-Up Problem
    By mgaman in forum CNC Machining Centers
    Last Post: 06-16-2012, 03:55 PM
  5. Replies: 4
    Last Post: 01-06-2009, 05:20 PM
