I'm CNC'ing this mill http://www.harborfreight.com/cpi/cta...emnumber=33686 with some electrocraft E712 motors.
Reliance Electric DC Brushed Servo Motors, Model E712
37.51 Oz-In/A
25.0-30.5 V/KRpm
Motor Terminal Resistance .75-1.02 Ohms @ 4A.
Maximum Terminal Voltage 60V
Maximum Continuous Speed 2100 RPM (No Load)
Maximum Peak Torque 1500 Oz-In.
Maximum Peak Current 44.5A
Maximum Continuous Stall Torque At Max Motor Temp 300 Oz-In.
Maximum Continuous Current 8.9A
One of the renco encoders is busted up. First off, are these going to be worth using? I've got 3 gecko g320's to drive these. The shafts are 1/2 inch. For uniformity I am wanting to replace all 3 encoders. Would the E3's from usdigital.com be what I am looking for? Using roton ballscrew 5/8x.200 and preloaded antibacklash nuts. Good setup or not? Any other suggestions? Also what kind of reduction should I be looking for. Where would I come across a 60 volt 30 or 40 amp power supply for it. Would it be enough?
