585,991 active members*
6,540 visitors online*
Thread: Milling 6063
    Jan 2010
    5
    Milling 6063
    I have been cutting parts out of 6061 and then I tried to cut the same parts from 6063 and it just does not cut as nice. I incorrectly assumed that with the 6063 being softer that it would cut much easier but that was not the experience I had.
    Any comments or suggestions? I am milling out of 1/2" plate.
    Thanks in advance to anyone that replies.
    Another beautiful day in sunny Michigan!
    - Tim - www.tracktrends.com
    Aug 2010
    54
    Milling Aluminum
    We just introduced our aluminum cutting end mills in the product release section of this site. The 2 flute ZRN coated would be the perfect for this application. The speeds and feed are listing in our listing. Coolant would help if you have it available.
    Best Regards,
    Marty
    Jan 2010
    5
    Thanks for the reply. I will check out your tooling.
    Yes, I am using coolant
    Aug 2010
    54
    Milling Aluminum
    Let us know if you need a link
    Best Regards,
    Marty
    [email protected]
    Phone 716 791 6197
    Aug 2010
    Question
    I assume you're using material in a T6 condition?
    The Manufacturing Reliquary
    http://cmailco.wordpress.com/
  1. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
  2. Milling .125 anod. 6063 K-shape extrusion
    By Jig Maker in forum CNC Tooling
    Last Post: 04-13-2010, 03:14 PM
  3. How to 3d milling?
    By Blauwtje2000 in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2009, 08:48 PM
  4. Offset Chain Milling vs Path Milling
    By ynnek in forum Uncategorised CAM Discussion
    Last Post: 03-11-2009, 11:29 PM
  5. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum Community Club House
    Last Post: 06-30-2008, 03:23 PM
