Im a self taught machinist using alphacam to cut mainly 2d profiles for foam inserts for cases.
i muddle through reasonably successfully but my latest insert is going to cause me headaches!!
On the attached image the arrow is pointing to an area i know is going to be tricky i think this area will pulll over the material and cut through the wall.
So my questions are.
how do i machine this successfully without it pulling over and cutting through the wall.
Do i use a 12mm tool or a 6mm ?
how many cuts? any suggestions for feed speed?
the depth of the foam is 75mm
Im using LD18 Platazote Polyethelene high density foam.
The thickness of this wall is about 12mm
im running at 24000 rpm
When im machining foam i always leave 2mm to pull out the insert later this allows me to machine finer wall thicknesses.
i need this to be as efficient as possible as i know i will be making a few of these.
