Originally Posted by
mad.sculpture
Hi,whilst looking around at different designs i came upon this also.
the bit i thought was good was those 1" blocks you mentioned on y slides supporting x rails because if you as a hobbyist had these cnc'd for you there wouldn't be much to cock up as far as alignment goes,you'd know x&y pretty good,flat sheet(poss thick) accross back between these and also on top and the x would be quite solid for low end machine.
thing is other than the z axis most everything else could come from marchant dice type people and be simple to align.plus if someone started selling 2 blocks like these which could i think be common to each other if you wanted a machine different sizes it'd be so easy to change as determined only by rod lengths really,you couldn't easily screw it up could you?
too much sag in rails, make 20 mm rail all round supported y rails actualy would be easy to do anyway.
wouldn't it be a great alternative to mdf for us newbies.
Never been able to see why marchant dice not do something like this,you can buy all the saddle blocks end end supports but why can't they publish more complete info as to how they all go together,you can by a complete twin round rail axis set but you still have to get the bits machined to take your leadscrew fittings etc and this could introduce errors.the set looks like cool vesatile axis fot 140 quid,but if you look what they charge for that axis with that bit of machining done it's like 500 quid.
as machining in volume brings prices down it makes sense for marchant dice type suppliers to get it done at source and charge a bit for it rather than us lot getting it done piecemeal.
Ross.
