585,692 active members*
4,964 visitors online*
    Dec 2007
    159
    SRV400 Servo System
    Hello once again my friends, I have another question or two. In some of my past posts I was trying to find info on retrofitting my 4896.Due to a big rush order it seemed logical to fix the router vs the retro, working out the bugs, and learning a new control.I ordered the repair parts which consisted of an amp board and a new servo for the Z axis. In a visual comparison the amps look almost identical.After installing the new electronics I must jog the Z axis up to reattach the gas spring.The motor moves in the negative direction instead of rising off of the support block.Thinking wayback I remembered I had to add a negative sign (-) in front of the scale factor to get the axis to change directions.After doing this I go ahead and check the scale factor with a dial indicator and it is measuring accurate and is jogging in the correct direction.Ok the first thing I want to do is home out the machine and run a test cut.Well I click the "Home All" button and the spindle moves down towards the table again which is the wrong direction.I am hoping someone has had this problem before and can tell me what I need to change.I am sure its something in the software somewhere.I appreciate you all for reading this long post.
    Mar 2008
    91
    Quote Originally Posted by advt001 View Post
    I don't run Techo's software, but do believe we approach things identically in terms of motion. That being said, you also need to flip the homing direction and not just scaling to negative. In my own software, it's an INI file flag, but I think for theirs it's a menu option. Unlike techno's method in terms of homing, X and Y are homed at the same time, after Z is homed but the logic is just the same. Look for Homing direction and flip that as well.
    Joe Jared - OsiruSoft Research and Engineering - http://www.oretek.com
    Dec 2007
    159
    Thanks Joe, I see what I can find tomorrow evening. Monday mornings aren't a good thing for me.
  1. Anyone ever retrofit a Servo II system?
    By frontrange in forum Post Processors for MC
    Last Post: 04-05-2020, 10:57 PM
  2. srv400 board
    By advt001 in forum Techno CNC
    Last Post: 09-08-2010, 09:15 PM
  3. Servo System ?
    By Kencor1 in forum Automation Technology Products
    Last Post: 03-08-2009, 06:43 PM
  4. Servo System Set Up
    By Gorillakilla in forum Servo Motors / Drives
    Last Post: 11-15-2005, 11:04 PM
  5. Servo system...what is needed?
    By Hobbiest in forum Servo Motors / Drives
    Last Post: 06-17-2004, 03:00 AM
