585,991 active members*
5,829 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Forged 6061-t versus 7075-t651
    Dec 2007
    9
    Hi Guys , i have been working in a racing billet brake calipers to my racing team.
    Now the design is read to be machined ,but i have some questions...
    Why the most billet calipers are maden from aluminium forged 6061-t ????
    I cant make forging process in my shop, so i guess, if i could use the 7075-t651 instead of forged 6061???
    Why do they use 6061 so much ? Is it a cheapest material?
    What is the hardness brineel diferences between 7075-t651 and forged 6061-t?
    Its easy to find 7075-t651 in my country (Brazil) ,the 6061 i cant find, only importing....
    Thanks guys
    Jul 2005
    12177
    Here are a couple of links with information about 7075 and 6061. I think 6061 is used because it is cheaper than 7075 and is widely available in North America. I also think anything that can be made out of 6061 can probably be made from 7075 without any problems other than 7075 not being as corrosion resistant as 6061.
    http://www.unitedaluminum.com/aaa.php
    http://en.wikipedia.org/wiki/7075_aluminium_alloy
    Dec 2007
    9
    i have a question...
    what is the strongest aluminium ??? forged 6061-t or 7075-t651???
    6061-t651=95 brinnel
    7075-t651=150 brinnel
    forged 6061=??????
    How much brinnel hardness increase the forging process on 6061??
    thanks
    Jul 2018
    Re: Forged 6061-t versus 7075-t651
    Hello Lourenco,
    have you found out which one is good ?
    Do you need help ?
    Kind regards
    May 2018
    13
    Quote Originally Posted by lourenco View Post
    Thanks guys
    Hi Lourenco, How easy is it to find 7075 in Brazil ? I need machinable Aluminum but can't seem to find anything but Al 2021 in Chile. I would consider importing 7075 from Brazil, so where would I find it, and roughly what's the price per kg ?
    Thanks for your help !
  1. need Material 8" 7075 T651 round bar
    By cruizer67 in forum Want To Buy...Need help!
    Last Post: 11-20-2013, 08:01 PM
  2. Alloy billet 6061 7075 supply
    By phantom1500 in forum Australia, New Zealand Club House
    Last Post: 03-15-2013, 06:11 AM
  3. Milling 6061-T651 Cast Plate
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 01-18-2010, 12:22 PM
  4. Surfacing 6061 T651 aluminum
    By hmc710 in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2009, 09:34 PM
  5. 7075-T6 to 6061-t6 welding?
    By AMCTony in forum Welding Brazing Soldering Sealing
    Last Post: 02-05-2007, 04:24 AM
