Hi all,
Okay I'm a newbie, both to this forum and to CNC in general, so please bear with me.
I am working on a recently refurbed fadal 8030 and it appears that I have a z axis repeatability problem when jogging. If I use a dial indicator and jog the head up and down at various rates and return to the same depth based on the monitor numbers, the dial indicator can be out anywhere up to 0.005".
Now if I run the same test but use a program to run the head up and down my repeatability is within machine spec +-0.0004 inches. In both tests I locked the spindle and ran the dial indicator down onto the bed.
Is it possible that when you jog, the backlash compensation is not accounted for? If this is the case, that means setting tool offsets would become a nightmare if you are manually jogging down to a height block. Any ideas?
Thanks.
