585,775 active members*
4,383 visitors online*
    Jan 2008
    74
    Fanuc 401 & 414 Servo Alarms
    Hello,
    I have a Takisawa TC-20 lathe with a Fanuc 21-TB control. For the past week or so in the morning when I started up, I would get a 414 X-Axis and Z-Axis Servo Alarm. I would then shut off the power again and restart. After a few rounds of this the alarm would disappear. However this morning it just won't go away. There was also a 401 X & Z Axis alarm this morning. That has disappeared but the 414 is persistent. Anybody have any troubleshooting tips?
    Feb 2009
    6028
    Sounds like your power supply is not charging. Probably a failing capacitor.
    414 Alarm5 bit6 Current conversion error alarm 3.2
    414 Alarm1 bit5 Overload alarm (OVC) 3.3.2
    414 Alarm1 bit3 1 DC link over-voltage alarm (HV) 3.1.2
    414 Alarm1 bit6 2 Low control power voltage alarm (LV) 3.1.2
    3 Low DC link voltage (LVDC) 3.1.2
    414 Alarm1 bit2 4 Regenerative discharge control circuit failure alarm (DCSW) 3.1.2
    5 Over-Regenerative discharge alarm (DCOH) 3.1.2
    414 Alarm5 bit5 7 Dynamic brake circuit failure alarm (DBRLY) 3.1.2
    414 Alarm1 bit4 8 L axis over- current alarm (HCL) 3.1.2
    8. L axis IPM alarm (IPML) 3.1.2
    9 M axis over- current alarm (HCM) 3.1.2
    9. M axis IPM alarm (IPMM) 3.1.2
    b L, M axis over- current alarm (HCLM) 3.1.2
    b. L, M axis IPM alarm (IPMLM) 3.1.2
    Jan 2008
    74
    Ok, thanks for the reply. You have given lots of information, I just need to know how to decipher it now. Are those bit values that I need to look up in the Diagnostics screen to figure out what the problem actually is? Thanks in advance for your help
    Dec 2009
    952
    hi m8
    look here maybe will solve u problem
    http://www.cnczone.com/forums/showthread.php?t=107139
    GOOD LUCK!
    Jan 2008
    74
    I did finally get it running again yesterday, but I'm getting the 414 errors again this morning. When I look at the diagnostics screen #200 and #204 are all zeros (which I understand is the way they should be). But #201, bit #4, EXP is set to 1. I can't quite figure out from the manual what this actually means.
  1. Fanuc Servo Alarms 401, 414, 424
    By sushrut in forum Fanuc
    Last Post: 10-20-2013, 09:31 PM
  2. LNC 8 servo and LDU alarms
    By Fudd in forum Okuma
    Last Post: 07-21-2010, 12:13 PM
  3. Fanuc 0t servo alarms
    By p1etaster in forum Fanuc
    Last Post: 11-05-2008, 09:26 PM
  4. Fanuc 400 alarms and other
    By alphatad in forum Fanuc
    Last Post: 02-04-2008, 03:32 PM
  5. Fanuc OT alarms
    By cncmike92 in forum Daewoo/Doosan
    Last Post: 04-23-2007, 01:57 PM
