586,005 active members*
4,878 visitors online*
    Feb 2007
    54
    paramteric programming for a fresnel lens
    We have the formulas to get output from a fresnel integral....we can even get that data on a spread sheet.
    How to write a program to take the data..better yet the formula inputs and turn it into G-Code
    Apr 2005
    263
    will you be making the lens on a lathe or on a mill?
    what material?
    does your output geometry look something like this?
    http://en.wikipedia.org/wiki/File:Fresnel_lens.svg
    Lens Manufacture
    I recall producing an Application for a UK client, a good few years back, which
    did exactly this.
    Basically the method was :-
    CAD Module
    Using VB script a macro was produced which produced the Curve based
    the equation and some other Parameters such as Included Angle+radius.
    The VB script would then calculate a series of points which lie on the
    curve.
    The VB script would then submit these points to the CAD Curve Fitting
    routine which would produce a Tangential (Convex or Concave) curve
    which then be passed to the CAM Turning module.
    CAM Turning Module
    The CAM turning module would then be used to produce a toolpath.
    This was a few years ago and since then the CAD module has aquired a Template system which could be employed and the CAD + CAM modules are available as Servers using microsoft auto technology.
    These new features make it possible to develope a fully automated Bespoke
    application which take the initial parameters and produce a dimensioned
    drawing and G code file witht he Dolphin modules being used as background servers invisible to the user.
    michael
    Dolphin CAD CAM systems Ltd
    Dolphin CAD CAM Ltd
    Jul 2010
    118
    if you can make the calculations in a xls spreadsheet, then you can also recreate these formula's in macro B (i can only speak about fanuc cnc's), no special software requiered.
    the calculation will save the point data in a sequential variable range, start & end number decided by you.
    then write a normal cnc part program that will call this variable-range in sequence to produce the shape calculated.
    the variable range is called by using a loop that index the variable number, making the program very short.
    Feb 2006
    1792
    Post the drawing and formulae for specific suggestions.
  1. DUAL FOCUS LENS (bifocal lens)
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-12-2013, 08:56 AM
  2. Paramteric Program
    By Ashish B in forum Parametric Programing
    Last Post: 02-25-2011, 07:44 AM
  3. Turning fresnel formula output into g-code
    By roger_e in forum Environmental / Alternate Energy
    Last Post: 09-24-2010, 09:39 AM
  4. Focusing lens
    By cmh6473 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-28-2009, 09:57 AM
  5. Where to buy lens?
    By medved in forum Mechanical Calculations/Engineering Design
    Last Post: 12-30-2005, 09:49 AM
