585,977 active members*
4,126 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Beginner. What size drill bit for snug fit 12mm hole?
Results 1 to 12 of 12
    Sep 2010
    Hi. I'm a newbie on the forums. What an incredible amount of information here! I hope someone can help me.
    I have only a small amount of metalworking experience... I just know the basics and that's fine, it's not my main thing (electronics is).
    I want to drill a hole with my mini lathe, in three or four different metals, to fit a 12.0mm dia insert into, in such a way that it is snug but not necessarily wedged in for ever.
    I have a 12mm drill bit which (as I was expecting) makes a hole slightly too big.. the insert has free play.
    Given the cost of decent 11.x mm drill bits, I don't want to buy 11.6, 11.7, 11.75, 11.8, 11.9 (you get the picture) just to find out which works best, if I only need to buy one or two.
    So which do you think I should buy?
    The 12mm dia (exactly, according to my micrometer) inserts are chromed brass. The four metal rods are about 30mm diameter in aluminium, copper, stainless steel and brass.
    Thanks for reading, and thanks in advance for any help.
    Norman
    Jul 2010
    You need an undersize reamer, available at MSC idustrial supply, for example.
    Drill the hole about 11,75 mm then ream thru'.
    Experiment with different speeds and cutting fluids as this can affect final size.
    Good luck
    Sep 2010
    That's great, thank you Mike.
    Best wishes
    Norman
    Mar 2008
    3655
    You're drilling on a mini lathe? Why not drill undersize and then bore to exact size required?
    Boring bar sets are cheap, and a must-have tool:
    http://littlemachineshop.com/product...3768&category=
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Sep 2010
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Genius! I knew something like this must exist, I just didn't know what it was.
    Thank you, much appreciated.
    Best wishes,
    Norman
    Mar 2008
    3655
    If you haven't watched them already, you might find the MIT lathe training videos interesting:
    http://crevicereamer.com/Page_70.html
    BTW: Welcome to the Zone!
    CR.
    Sep 2010
    Thanks for the link... and the welcome :cheers:
    Norman
    Mar 2008
    240
    Buy a 12H7 reamer. Drill 11.7 and ream. Slow with good lubricant. Check. If to loose - stone the reamer lightly with an oil stone.
    Sep 2010
    I understand that a reamer is that much more accurate than a drill, I just don't understand why. They look to me as if they do essentially the same thing, as far as the diameter of the hole goes.... they are both hard, fast-spinny, sharp-edged things.
    I don't get it.
    Dec 2009
    82
    The first time you drill a hole, it will always be over-sized compared to the size of a drill bit. This is from heat expansion and the chips clogging the flutes of the drill.
    For holes that need to be more accurate, its best to pre-drill with a slightly smaller drill bit, then drill again to the final size.
    If even more accuracy is required, like in your place, a Reamer or Boring bar is used after a hole has been pre-drilled.
    A reamer cannot be used to start a hole, it would probably break. Reamers produce accurate holes because the cutting surface (the blades) are ground to size. Also, because of the small amount of material they remove, there is not much heat build up to deform the hole.
    Mar 2004
    1306
    Depending on what you are making and what level of accuracy is needed, drills don't make accurately located, round, correct sized holes. They are great at rapid metal removal though.
    If you want an accurately located, round hole of a specific size:
    You use drills to bring the hole to 0.5 - 1.0mm under sized. This is metal removal. The hole will not be perfectly located, round or straight.
    Then bore the hole up to about 0.1 -0.2mm under - this centers the the hole to your lathe spindle axis, makes it round, and straightens it.
    Then ream it to size, as reamers give accurate diameter and predictable surface finish.
    Running a reamer down a drilled hole won't straighten the hole or bring it back to it's desireed center.
    Regards,
    Mark
    Mar 2008
    240
    Norman- just take our word for it. A detailed explanation would require you to enter a training program and years of experience. No offense please! I like the way you show interest in metal working.
  1. Replies: 9
    Last Post: 02-11-2008, 05:54 PM
  2. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
  3. How would you drill this hole.
    By Loading in forum MetalWork Discussion
    Last Post: 10-05-2006, 06:00 AM
  4. drill hole
    By larry53 in forum MetalWork Discussion
    Last Post: 05-20-2006, 12:50 AM
  5. Drill hole
    By avengine in forum Community Club House
    Last Post: 04-30-2006, 01:33 AM
