Machine no longer working and when i click on any button nothing happens
Thank you in advance for any advice or information
sorry for my English
hello,
first of all, what cnc is built on the machine ?
well, you get started the main pump ?
have you check the emergency buttons, maybe one is pressed...
check also the fuses in the control cabinet...
if you have a cnc on the machine, you get any error message or any other warning message ?
thats all for now...
regards
it can also be the small KEY on the monitor (keyboard protect ON / OFF)
or simular...
Ok, we have an Amass at work just the same prob happens all the time. With ours we discovered there was a short in the wires from control box to circuit board. As the control box can be adjusted to the ops needs it develops short in wires due to movement. Check there. If not then check your files through bendcad if you have it, files can cause errors unknown if written wrong or have incorrect punch and die info.
Amada, sorry. Auto correct is on.
