Hi guys.
I have the need for a very specialized grinder- one which will rotate a workpiece against a grinding wheel, which will move in and out to grind a profile on the rotating work piece.
Anyways- I've considered converting a surface grinder, and several other things, but i'm sort of thinking of just building from scratch.
Speed is not a concern, just accuracy and surface finish.
What I was thinking was-
Start off with a thick granite inspection plate. Mount the rotary to one side of that. Any ideas on what type of rotary table I need to purchase? I need something which will work with mach 3 or similar- and it needs to provide .05 or .1 degree encoder steps.
Place a well made 3 jaw chuck or expanding collet on the rotary to hold the work piece through its center bore.
Now, on the opposite side of the inspection plate- put a thick piece of granite or steel, ground to appropriate thickness. Waterjet (granite) or machine (steel) holes in this to mount good quality precision linear ways. On top of those, your grinding head (type?) would be placed.
I'd probably mount all that vertically, and provide some dust protection for the linear ways / ballscrew / encoder. Mounting it vertically does two things for me- the ballscrew will always be loaded in one direction. Two, the dust will fall away from the rails, screws, etc- rather then onto them.
Any feedback?
Does this sound like something mach 3 can control?
