585,676 active members*
5,961 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Jun 2004
    258
    Postprocessor for Alphacam
    Hello..
    Can anyone help with a postprocessor for Alphacam......
    your help appreciated..
    cheers
    Frans
    Feb 2005
    921
    I have been trying to figure out a few things about AlphaCams post processor lately also.
    I think Frans got a post from Bob Campbell.
    Mar 2004
    16
    Alphacam post
    I can do them.
    But I do charge - relatively inexpensive when compared to vendor prices.
    Interested? I will need to know machine, control and basic axis configuration.
    Andy NC
    Andy
    Mar 2006
    7
    postprocessor
    Quote Originally Posted by Andy NC
    I can do them.
    Andy NC
    How much is it for a postprocessor Alphacam to NUM750 ??
    Mar 2004
    16
    Post Processor
    £200 GBP NC code will be perfect (i.e. right first time)
    Can trade via web and PayPAL for security.
    Let me know what you think
    Andy
    Andy
    Mar 2006
    7
    postprocessor
    Can you make me a postprocessor AlphACAM - Record 2 NUM750.
    I have the old one made for DOS. Is that of any help ?
    Mar 2004
    16
    Post Processor
    If it was a DOS post processor for the DOS version of AlphaCAM (which was called APS) it will automatically be converted once AlphaCAM is loaded. No need to buy a new one.
    Simply ensure the old LicomDAT folder is on the PC you are installing AlphaCAM onto and the installation procedure should take care of everything.
    If its not for APS then its useless to me. I can make a new one in this case.
    You will need to send me details of the machine...
    Number of spindles
    Number of vertical drills
    Number of X axis horizontal drills
    Number of Y axis horizontal drills
    Saw unit details etc.
    Does the machine have 2 vacuum zones?
    I will be happy to send test NC programs from the post processor for you to test.
    Andy
    Andy
    Mar 2006
    7
    postprocessor
    I send you all info. that you need.
    it is better to send directly to your emailadress
    My emailadress
    [email protected]
    can you mail me???
    Mar 2006
    7
    postprocessor
    [IMG]Data[/IMG]
    Number of spindles
    Andy
    Mar 2006
    7
    Do you need more details ??
    Attached Files Attached Files
    Mar 2006
    I can do them.
    Andy NC
    Andy NC,
    Looking for alphacam post for Anilam 5300 Mk controller .
    On standard 3 axis milling MC.
    Mar 2006
    7
    Can you make a postprocessor out of the data I gave you ?
    lerken
    Mar 2004
    16
    Post processor
    No problem just send me a couple of sample NC programs,
    Need to show me a wide range of functions e.g. lines, arcs, drilling/pecking/tapping cycles, radius compensation,
    Cost is £200 GBP. Will accept payment via paypal.
    Waitng on your reply
    Andy NC
    Andy
    Mar 2004
    16
    Num 750. Poor quality photocopies but enough to get started.
    Will send a sample program very soon.
    Andy NC
    Andy
    Mar 2006
    Andy,
    You can contact me directly at [email protected]
    Can I email sample progs directly to you and arrange payment.
    Many Thanks.
    Mar 2006
    Alphacam post
    Andy NC,
    Attached is Manual containing G codes and canned cycles for my
    machine.Wont be using any pocketing cycles for machining just using canned
    cycles for drilling,peck drilling,boring,tapping and reaming.
    Can you let me know me you have enough information,sorry for the delay as
    I was away.
    Tuohye
    Dec 2012
    Hello.
    I have a problem with the post postprocessor. I am working a pade uni5 with alphacam 2012R2. so when i am working with 5 axis and c axis goes up to 95o the machine stop working.
    can anyone tell me which is the command that I have to use in the nc code, in order to change the interpolation of the C and A axis when the machine comes to overstroke and stops running?
    I need the command to rotate the C axis to -180 or +180 and at the same time to mirror the A axis.
    Re: Postprocessor for Alphacam
    andy nc ,
    need a post for alphacam to busellato evolution 2.3
    email is [email protected]
    Hola Andy NC ,leí por el sitio que vos podés hacer un postprocesador para alphacam , tengo un SCM tech z25 que utiliza xilog plus y no puedo hacer que funcione con alphacam , me podrías decir si podés y cuánto vale hacer el posprocesador.
    Mi correo es [email protected]
Page 1 of 2 12
  1. AlphaCAM 00 and AlphaCAM V5 - same postprocessor
    By Ziyan in forum CNC Machining Centers
    Last Post: 10-10-2011, 12:59 AM
  2. need help in VBA alphacam postprocessor
    By basim in forum Visual Basic
    Last Post: 02-13-2010, 02:04 PM
