i am currently making a new control board for my cnc router (here ) but have hit a wierd part.
For the most i am copying the old board, however the power to the drivers (and thus to the steppers) is a bit weird..
They had a torroydal transformer (OP 25vac - 120VA) going into a recifier, going into a big smoothing cap - output 40VDC. good fo far, i was going to use it like that, however, they also had a strange circuit, using a BDX33C "Power Darlington TR" (DATASHEET )
and a potential divider on the base.
Heres the two circuits, first their one, then the one i was going to use.
(not the resistor on the potential divider measures 0.89Kohm (with broken track) but the colours read it as 1.8K - WTF???)
anyway, is there any advantage to doing it their way, or am i ok using the simpiler meathod (not using the darlington "NPN Epitaxial Transistor")
Cheers
Alex
EDIT: that diode is a BZX 55C 39
all this circuit seems to do is make that 1k resistor hot...
