585,737 active members*
4,627 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Partner knee mill question
    Feb 2010
    54
    The monitor has a socket on the side for an external keyboard. This socket is about 1/2" dia and has 5 pins with a notch at the top. Doesn't look like a PS2, it's a bit older. Any idea what kind of connector this is and where to get a keyboard that will plug into it?
    Mar 2010
    It is likely an AT style keyboard connector. This adapter will connect to a standard PS2 keyboard.
    Monoprice
    Feb 2010
    54
    Thanks! Glad to know I don't need to run around looking for an antique keyboard.
  1. feedback on a Z axis kit for a knee mill and mill drill
    By extsuba in forum Vertical Mill, Lathe Project Log
    Last Post: 04-01-2009, 12:06 AM
  2. knee mill vs bed mill, brimingham, enco, jet other
    By allenpnx in forum Knee Vertical Mills
    Last Post: 12-19-2007, 03:56 AM
  3. Knee Mill vs Square Column Mill
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 01:27 AM
  4. 8x 36 knee mill spindle speed question
    By krumly in forum Knee Vertical Mills
    Last Post: 11-07-2007, 10:22 PM
