585,712 active members*
3,811 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Please kindly advice me.
Results 1 to 11 of 11
    Sep 2010
    To all masters and sifus out there please help me on which tools ans accessories to purchase for beginner.
    I am purchasing a mini vertical mill similar to Seig X2. I am doing some aluminium parts.
    1) What kind of milling bits should I purchase? (Rounding corner, slots etc)
    2) Should I purchase quick conect R8 Chuck and collet? (Which type and size)
    3) Other ensential tools like sanding or smoothing edge, cutting tools etc.
    Your advice is very much appreciated.
    Sep 2010
    How about rotary table?
    Jul 2010
    How about you take a basic machining class.
    Sep 2010
    Hi Mike,
    Thanks for sudgestion. Unfortunately there is no basic / short class available here. I just have to self studies and get informations from other masters.
    And also I am in a small budget to do this. So a lots of things had to be improvise.
    Sep 2010
    Quote Originally Posted by MikeZee View Post
    Hi Mike.
    Thanks for advice. Unfortunately here don't have short or basic class. I had to rely on self studies and gathering informations from masters like u.
    Further more I am runing on small budget.
    WH Ng
    Sep 2010
    BUMP
    Sep 2007
    359
    Your question is too vague so the answers will be too long.
    A better way is to ask How do i make this and what tools would i need to make it but remember i am on a budget.
    Look for stuff on ebay if available to your country
    But to get the ball rolling you need
    Collets
    Drill chuck
    Machine vice
    Range of drills
    Range of cutters
    Measuring/setting devices
    Sep 2010
    Quote Originally Posted by M250cnc View Post
    Collets
    Drill chuck
    Machine vice
    Range of drills
    Range of cutters
    Thanks alot M250CNC
    I am doing some aluminium & plastic material.
    Will be making some slots, holes and threads
    To mill slots do I use end mill size same as the slot or use smaller size to do a few runs?
    What tool can make a specific angle (degree) countersink for a 15mm hole?
    How do I mill corner or half outer round?
    Collets>>>>> like ER16 etc?
    Drill chuck >>>>> R8 Quick connect?
    Machine vice >>>>> Rotable or fix?
    Range of drills >>> this I understand
    Range of cutters >>> end mill? indexable?
    Measuring/setting devices >>>> this I understand
    Thanks again
    Sep 2007
    359
    The collets depend on your machine spindle an R8 is the better choice.
    If it has an R8 then you will need R8 collets or if is morse taper you can get morse taper collets
    Or you could get a collet chuck for a morse taper and use er collets depending on the size of the holder and yes they are available in to suit R8
    So you can see there is a lot of choice and some people have some of each.
    The vice can be swivel and or tilting but they tend to be less rigid and take up more space and on a small machine they can eat up all your capacity and cost more but you can have both and again some people do.
    You always use a smaller cutter if you want precision for the slot very popular are three flute cutters as they have advantages of end mills and slot drills
    Indexable only come in the larger sizes
    Carbide is longer lasting and works good on ali, HSS can have a sharper edge and may suit plastic better.
    For countersinking you need a countersink, they are available in lots of sizes.
    But like rules, they are meant to be broken
    You can do a search on ebay then you can see what is available, and what they cost.
    Sep 2010
    Thanks a lot.
    How to mill corner? or half outer round. and how to mill an angle counter sink biger than the drill bit?
    Sep 2007
    359
    On a manual mill there are rotary tables and also corner rounding cutters.
    The corner rounding cutters are the easiest but the angles are a maximum of 90 degrees and large radii are not readily available.
    The exact method would depend on the part.
  1. General advice and equipment advice
    By GeorgiaRaised85 in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2010, 11:00 AM
  2. Need some Advice
    By legomanww in forum CNC Wood Router Project Log
    Last Post: 07-06-2007, 11:10 PM
  3. New and in need of some advice... well alot of advice!
    By GoonShoes in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2007, 01:03 PM
  4. new to cnc need advice
    By extremecanvas in forum Commercial CNC Wood Routers
    Last Post: 10-02-2006, 09:09 AM
