I have a possible upcoming job where I could really use a full 4th axis to do some contouring. Actually I'd be engraving text onto a cylinder...
Let's say that I have a BMC-20 with Fanuc drives, running Ultimax II V8.60. It's got the "old style" 2 LED dual axis cards.
Let's also say that I have a spare, single axis Fanuc analog AC servo drive and a compatible powered rotary table. However, I don't know the encoder counts on the motor - 2500 PPR probably. I also don't know the degrees/rev of the motor to rotary table. Both of these I can find out, just not right now.
What do I need to add to the control to bring this together? I assume I need another dual axis card. Does this need to be the 2-led version, or could it be the newer version? I also suppose I'd need different EPROM's in the dual axis card if it was originally an X/Y or Z/S card. Naturally the cabling between the dual axis card and the CRP board, and the CRP board to the drive would be needed which is no problem. Presumably the 0 degree microswitch needs to be hooked up (where?), unless calibrating 0 is handled in another fashion.
I think I can get a used dual-axis card. Is there more that is needed? If Ultimax needs an upgrade that's probably not in the budget.
