585,991 active members*
5,407 visitors online*
    Oct 2010
    Shoptask 1720 XMTC add CNC
    Hi All! Im new here and just bought a Shoptask 1720 XMTC used for 500.00. It has x/y steppers on it and was interested in adding CNC. The guy I bought it from has some gekko controllers on another unit and siad to use those. Anyone done this setup and what would I need to make it happen? I have a computer, just need the hardware and software. Thanks and great forums!
    Doug
    Feb 2009
    281
    Quote Originally Posted by mustangdug View Post
    Doug
    Gecko is a good choice for your drivers, but you need to match the motors and wire them properly. You will need a motor on the Z axis unless you are going to use it strictly as a CNC lathe. Shoptask sells a hardware kit for about 40 bucks that includes the belts, nuts and bolts and some torrington bearings to reduce lash in the Z axis. Mach III is a good software to try.
    Feb 2009
    180
    Quote Originally Posted by instructor37 View Post
    On the older machines, you would be miles ahead to buy the ball screw kit from Shoptask for the Z axis. The X, Y table works good in original configuration for CNC, but the Z axis needs the ball screw to really work well.
  1. Shoptask 1720 XMTC mill spindle runout?
    By Knn in forum Shopmaster/Shoptask
    Last Post: 10-12-2010, 06:50 PM
  2. 1720 XMTC Manual and Compound Slide
    By grahasp in forum Shopmaster/Shoptask
    Last Post: 08-07-2010, 06:57 PM
  3. 1720 XMTC White - quill tool holder?
    Last Post: 10-16-2009, 05:36 PM
  4. basic ?s on Shoptask 1720
    By laskaboots in forum MetalWork Discussion
    Last Post: 08-11-2007, 05:49 PM
  5. 1997 Shoptask 1720 Gold
    By Rainone in forum Shopmaster/Shoptask
    Last Post: 05-09-2007, 04:49 PM
