Gentlemen,
I have a Doosan TT1800 with a Fanuc 18i control, and I was wondering if there is a parameter to switch so when I run a macro that it will show the macro being ran instead of just showing the G65 line and it's arguments. Thank You:cheers:
Gentlemen,
I believe parameter 3232 bit 1=1 to display 9000 programs, and bit 0=1 for 8000 programs.
I run a 31i and I want the opposite - is this possible also?
DP
My TT1800 with the 18i control has parameter 3232 but no ND8 or ND9.
Does this matter?
No joy on 31i...:violin:
DP
I tried parameter 3232 and it did not work, the control is a 18i-TB if that makes a difference? Any other ideas?
parameter 3202 bit 0
Editing of subprograms with program numbers 8000 to 8999
0 : Not inhibited
1 : Inhibited
The following edit operations are disabled:
(1) Program deletion (Even when deletion of all programs is specified,
programs with program numbers 8000 to 8999 are not deleted.)
(2) Program output (Even when outputting all programs is specified,
programs with program numbers 8000 to 8999 are not output.)
(3) Program number search
(4) Program editing of registered programs
(5) Program registration
(6) Program collation
(7) Displaying programs
parameter 3202 bit 4
Editing of subprograms with program numbers 9000 to 9999
0 : Not inhibited
1 : Inhibited
The following program editing during operation is invalid.
programs with program numbers 9000 to 9999 are not deleted.)
(2) Program punching (Even when punching of all programs is specified,
programs with program numbers 9000 to 9999 are not punched.)
(4) Program editing after registration
Same parameter for Fanuc 32i
on 18i its #3202 bit 4 =NE9(no edit 9000)
#3202 bit 0 =NE8(no edit 8000)
NE means no edit (NE8/NE9): param 3202
ND means no display (ND8/ND9): param 3232
I can have parameter 3232 bit 8 and 9 with a 0 or a 1 and there is no change it shows G65 macro line and it's arguments. Now I only changed the top turret or the main spindle, should I have done both to see results?
Yes I did, sorry about that
3232 are all 0, still does not display macro and/or subprogram
Any other ideas?
I'm at a loss.
Ok that is really odd. If I look in the 18i model A parameter manual it does not show parameter 3232 but in the model B manual it show parameter 3232.
If you unlock the 9000 programs with parameter 3202.4 will it display them on the control? As a few have pointed out in line 7 of the parameter is says (7) Displaying of programs. This may mean that they just will not show in the library.
I remember going thru this same problem on the same control some time ago but do not recall the outcome. Is this maybe an oversight from model A to B by Fanuc??
Stevo
would this work for 0i-td control.
