586,009 active members*
4,852 visitors online*
    Feb 2006
    251
    A boring subject
    Am getting ready to bore some holes and didn't know if there was some kind of special G Code that is required for the Tormach Mach3 and a offset boring head, but then I realised that the holes are solid numbers. For example, the oil seal bore is .750" so the .753" oil seal can be pressed in. So my question is, could I just interpolate a .745" hole with a 1/2" end mill and then change to a .750" end mill that just centers over the hole and plunges straight in with a drill cycle? Will the bore be accurate and clean enough to press seals or bearing into them? I assume the Tormach will have enough power and be rigid enough, it is 6061 aluminum and the bore is only .250" deep.
    Thanks, Tyson
    BlueFin CNC LLC
    Southern Oregon
    Sep 2005
    540
    I would think it should work assuming the mill is the correct size. A reamer would be a better choice but if you are like me there isn't likely to be a 3/4 inch reamer sitting around. I have done something similar but for 3/8 inch holes.
    Why don't you try it on a scrape piece and see what the results are...
    Robert
    holes are easy
    Yes use an end mill, I do this all the time, I use finishing contour cuts in Sprut for this. If the hole is a little off in diameter change your tool diameter info to account for this. If the hole is small change your end mill diameter for that tool to a smaller diameter, larger the opposite applies.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Feb 2006
    251
    Thanks guys, I will give this a try when I get the stuff, don't have a good 3/4" end mill or the seal to press in, but the more I think about it I just don't see why this would not work.
    Tyson
    BlueFin CNC LLC
    Southern Oregon
    Endmill
    Any size endmill will work. I would use a 1/4" or 3/8" end mill.
  1. Indexable boring bar in boring head?
    By Molochnik in forum MetalWork Discussion
    Last Post: 04-15-2010, 01:36 PM
  2. Boring
    By opshop in forum MetalWork Discussion
    Last Post: 03-03-2010, 01:18 PM
  3. 6" Deep boring w/ 8" 0.625 boring bar
    By Donkey Hotey in forum MetalWork Discussion
    Last Post: 02-23-2010, 11:51 AM
  4. finish type for aluminum parts subject to temperature cycling
    By hyperdyne in forum Material Machining Solutions
    Last Post: 04-04-2009, 05:20 PM
