584,826 active members*
5,091 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad cam outputs M33 G84 G98,I dont want M33.
    Nov 2005
    57
    I try to drill and tap a M12 thread in my Bobcad V23,but the cam outputs via predator postprocessor code M33 before G98 G84, the problem is my old mazak mazatrol M2 dont accept M33 sence it is command for the tool measure unit out.
    Please help.
    Sve0019.
    Apr 2008
    1577
    Try zipping up your .MillPst file you are using and upload it here to the forum. Someone can probably get you fixed up.
    Nov 2005
    57
    Customization file for MAZATROL CAM M-2 - Metric
    Post variables listed in MillPostVariables.pst
    ****Version number MONTH DAY YEAR****
    1000. Version Information = Version Month Day Year? "2.0 10 03 2007"
    0. File header
    "O",prog_n,"(",prog_name,")"
    1. Start of file programmed zero
    n,"(",output_date," ",output_time,")"
    n,"(",machine_make,machine_model,")"
    n,user_comment_1
    n,user_comment_2
    n,user_comment_3
    n,user_comment_4
    n,user_comment_5
    n,user_comment_6
    n,user_comment_7
    n,user_comment_8
    n,user_comment_9
    n,user_comment_10
    n,user_comment_11
    n,user_comment_12
    n,user_comment_13
    n,user_comment_14
    n,user_comment_15
    output_tool_list
    n,absolute_coord,cancel_drill_cycle,cancel_offset, "G17",rapid_move
    n,rapid_move,incremental_coord,"G28","Z0."
    n,rapid_move,incremental_coord,"G28","X0.","Y0."
    n,system_comment
    n,feature_name_comment
    n,"M06",t
    n,spindle_on,s
    n,rapid_move,work_coord,absolute_coord,force_x,xr, force_y,yr,rotary_xyr_angle,
    n,length_offset
    n,coolant_on
    output_rotary_angle
    2. Start of file Standard
    n,user_comment_1
    n,user_comment_2
    n,user_comment_3
    n,user_comment_4
    n,user_comment_5
    n,user_comment_6
    n,user_comment_7
    n,user_comment_8
    n,user_comment_9
    n,user_comment_10
    n,user_comment_11
    n,user_comment_12
    n,user_comment_13
    n,user_comment_14
    n,user_comment_15
    output_tool_list
    n,system_comment
    n,"M06",t
    n,spindle_on,s
    n,length_offset
    n,coolant_on
    output_rotary_angle
    3. Tool change
    n,coolant_off
    n,,spindle_off
    n,rapid_move,incremental_coord,"G30","Z0.","H0"
    n,system_comment
    n,"M06",t
    n,spindle_on,s
    n,length_offset
    n,coolant_on
    output_rotary_angle
    4. Null tool change
    n,system_comment
    n,rapid_move,work_coord,force_x,xr,force_y,yr,rota ry_xyr_angle,
    output_rotary_angle
    5. End of file for non-zero tool
    n,coolant_off
    n,spindle_off
    n,incremental_coord,"G28","Z0."
    n,incremental_coord,"G28","X0.","Y0."
    n,end_of_file
    n,"M30"
    6. Optional Stop
    7. Sub program call
    n,sub_call,sub_num
    8. Sub definition
    n,sub_num_with_prefix
    force_x,force_y,force_z
    9. Sub program return
    n,sub_return
    11. Cancel cutter compensation
    "G40"
    12. Cutter compensation left
    "G41",d_offset
    13. Cutter compensation right
    "G42",d_offset
    14. Tool length compensation
    " G43",force_z,zr,h
    20. Spindle speed low range
    21. Spindle speed high range
    22. Rigid tapping start.
    n,"M33"
    23. Rigid tapping end.
    n,"M32"
    24. File trailer.
    25. Format for offset when using offset registers.
    26. Set debug.
    debug_off
    27. First Rapid Move.
    n,rapid_move,zr
    28. Rapid Move.
    n,rapid_move,zr
    40. Start of 2axis contour.
    50. Line first rapid move Z.
    n,rapid_move,zr
    51. Line feed move Z.
    n,feed_move,z_f,feed_rate
    52. Line rapid move XY.
    n,rapid_move,xr,yr,rotary_xyr_angle,
    53. Line feed move XY.
    n,cc,feed_move,x_f,y_f,feed_rate
    54. Line rapid move XYZ.
    n,rapid_move,xr,yr,zr
    55. Line feed move XYZ.
    n,feed_move,x_f,y_f,z_f,feed_rate
    56. Line feed move XY on Leadin.
    57. Line feed move XY on Leadout.
    64. Arc move.
    n,g_arc_move,x_f,y_f,arc_center,z_f,feed_rate
    71. End of 2axis cutting.
    73. High speed peck drill canned cycle.
    n,g_canned_cycle,g98_g99,x_f,y_f,drill_depth,refer ence_plane,peck_drill_increment,canned_feed_rate
    74. Left handed tapping canned cycle.
    rigid_tapping_start
    n,g_canned_cycle,g98_g99,x_f,y_f,drill_depth,refer ence_plane,canned_feed_rate
    76. Fine boring canned cycle.
    80. Drill canned cycle cancel.
    rigid_tapping_end
    n,cancel_drill_cycle
    81. Standard drill canned cycle.
    82. Standard drill canned cycle with dwell.
    n,g_canned_cycle,g98_g99,x_f,y_f,drill_depth,refer ence_plane,canned_feed_rate,dwell
    83. Peck drill canned cycle.
    84. Tapping canned cycle.
    rigid_tapping_start
    85. Boring cycle #1 canned cycle.
    86. Boring cycle #2 canned cycle.
    87. Back boring cycle canned cycle.
    88. Boring cycle #1 canned cycle with dwell.
    89. Boring cycle #2 canned cycle with dwell.
    90. Canned cycle drill point format WITH SUBPROGRAMS.
    n,x_f,y_f,z_f,canned_feed_rate
    91. Canned cycle drill point format for standard drill canned cycle NO SUBPROGRAMS.
    92. Canned cycle drill point format for standard drill canned cycle with dwell NO SUBPROGRAMS.
    93. Canned cycle drill point format for peck drill canned cycle NO SUBPROGRAMS.
    94. Canned cycle drill point format for tapping canned cycle NO SUBPROGRAMS.
    95. Canned cycle drill point format for boring cycle #1 canned cycle NO SUBPROGRAMS.
    96. Canned cycle drill point format for boring cycle #2 canned cycle NO SUBPROGRAMS.
    97. Canned cycle drill point format for back boring cycle canned cycle NO SUBPROGRAMS.
    98. Canned cycle drill point format for boring cycle #1 canned cycle with dwell NO SUBPROGRAMS.
    99. Canned cycle drill point format for boring cycle #2 canned cycle with dwell NO SUBPROGRAMS.
    100. Absolute coordinate output.
    n,absolute_coord
    101. Incremental coordinate output.
    n,incremental_coord
    110. Tool list format.
    n,"( T",list_tool_number," ",tool_name,", DIAMETER = ",tool_diameter,", LENGTH = ",tool_length," )"
    113. Canned cycle drill point format for high speed peck drill canned cycle NO SUBPROGRAMS.
    114. Canned cycle drill point format for left handed tapping canned cycle NO SUBPROGRAMS.
    116. Canned cycle drill point format for fine boring canned cycle NO SUBPROGRAMS.
    200. Is X modal? y
    201. Is Y modal? y
    202. Is Z modal? y
    203. Are the g codes modal? y
    204. Are the g codes (G02 and G03) modal in arc milling? n
    205. Are the xy (or yz or xz) coordinates modal in arc milling? n
    206. Are work coordiantes modal ? n
    207. Output sequence numbers in subprograms ? y
    208. Output sequence numbers? y
    209. Number of places for sequence numbers? 1
    210. Delete the decimal point? n
    211. Delete leading zeros? y
    212. Delete trailing zeros? y
    213. English or Metric format (E/M)? M
    214. Places before decimal point for reals (X, Y, Z)? 1
    215. Number of places for G and M codes? 1
    216. Places after decimal for feedrate ? 3
    217. Scale factor for feedrate ? 1
    219. Add spaces to the program? y
    221. Break arcs into quadrants? n
    222. Arc center a=absolute, b=incremental, d=unsigned inc., e=radius? b
    223. Break arcs into two pieces if greater than 180 degrees? n
    227. Output G40 after, rather than with, the last linear or arc move? y
    230. Use Standard drilling canned cycle? y
    231. Use peck drill canned cycle? y
    232. Use High speed peck drill canned cycle? y
    233. Use tapping canned cycle? y
    234. Use boring cycle #1 canned cycle? y
    235. Use boring cycle #2 canned cycle? y
    236. Use back boring cycle canned cycle? y
    237. Use left hand tap cycle canned cycle? y
    238. Use fine boring cycle canned cycle? y
    240. Amount to add to t to obtain t1? 0
    241. Amount to add to t to obtain t2? 0
    242. Value of t1 at t = 0? 0
    243. Value of t2 at t = 0? 0
    258. Maximum number of work offsets? 100
    262. Add sign to all coordinate values? n
    267. Amount to add to tool # for tool register value? 0
    272. Rigid tapping? y
    273. Output programmable rotary axis codes? y
    313. Z clearance for auto Z programming for XY move? 0.20000
    314. Z clearance for auto Z programming for cutting? 0.00000
    315. Minimum part heigth? 0.00000
    414. Number of decimal places for metric numbers ? 3
    415. Number of decimal places for english numbers? 4
    425. Number of decimal for angles? 2
    426. Number of leading decimal places for angles? 1
    427. Tapping feed rate (1=ipm 2=ipr)? 2
    428. Feed rates other than tapping (1=ipm 2=ipr)? 1
    429. Maximum spindle speed for tapping? 1000
    430. Maximum spindle speed? 10000
    431. Spindle speed for high rangle? 10000
    432. Add amount for tool number in tool list? 0
    433. Maximum sequence number allowed (used when #534 is y)? 9999
    511. Use incremental coordinates? n
    512. Use block delete for stop codes (M00)? n
    513. Output F feedrate values? n
    515. Output G99 instead of G98 in drilling? n
    516. Output G98/G99 in drilling? y
    518. Output M00 codes? n
    526. Start renumbering from start number for subprograms? n
    527. Create subdirectory for nc file? n
    531. Replace spaces in comment with commas ? n
    533. Output suprograms at the beginning of the program? n
    534. Re-Start sequence numbering once max sequence number is reached? n
    535. Are Feed Rates modal? y
    536. Force all codes to upper case ? y
    605. Spindle speed prefix? "S"
    606. Feedrate prefix? "F"
    607. Dwell prefix? "P"
    610. Miscellaneous end of file string? ""
    613. Pattern contour subprogram start code? ""
    614. Inch mode machining? "G20"
    615. Metric mode machining? "G21"
    620. Absolute coordinates? "G90"
    621. Incremental coordinates? "G91"
    622. Coordinate zero set? "G92"
    625. End of file? "M02"
    626. Stop? "M00"
    627. Optional Stop? "M01"
    628. Subprogram call? "M98"
    629. Subprogram return? "M99"
    630. Comment Start? "("
    631. Comment End? ")"
    639. Cancel wire offset? "G40"
    641. Prefix for radius values? "R"
    642. Prefix for arc X center? "I"
    643. Prefix for arc Y center? "J"
    645. Subprogram prefix? "O"
    646. Machine maker? "MAZATROL"
    647. Machine model? "CAM M-2 - METRIC"
    648. Part Height prefix? "None"
    649. Reference Plane prefix? "R"
    650. Wire comp left? "G41"
    651. Wire comp right? "G42"
    656. Block delete? "/"
    658. Subprogram call subnumber prefix? "P"
    659. Add these characters to the end of each line? ""
    670. Spindle forward string? "M03"
    671. Spindle reverse string? "M04"
    672. Spindle off string? "M05"
    673. Coolant on string? "M08"
    674. Coolant off String? "M09"
    675. First peck prefix? "I"
    676. Peck drill prefix? "Q"
    677. Drill depth prefix? "Z"
    678. Cutter offset prefix? "D"
    679. Cancel drilling canned cycle? "G80"
    680. GCode for Rapid Move? "G00"
    681. GCode for Feed Move? "G01"
    682. GCode for Arc CW? "G02"
    683. GCode for Arc CCW? "G03"
    684. Prefix for X Move? "X"
    685. Prefix for Y Move? "Y"
    686. Prefix for Z Move? "Z"
    687. Prefix for drill canned cycle feed rate? "F"
    688. Prefix for tool length offset? "H"
    689. Prefix for initial plane? "I"
    800. Standard drilling cycle no dwell #1? "G81"
    801. Peck drill cycle no dwell #2? "G83"
    802. High speed peck drill cycle no dwell #3? "G73"
    803. Tapping cycle no dwell #4? "G84"
    804. Boring cycle #1 no dwell #5? "G85"
    805. Boring cycle #2 no dwell #6? "G86"
    806. Back boring cycle no dwell #7? "G87"
    807. Left hand tapping cycle no dwell #8? "G74"
    808. Fine boring cycle no dwell #9? "G76"
    809. Hole making cycle no dwell #10?""
    810. Hole making cycle no dwell #11?""
    811. Hole making cycle no dwell #12?""
    820. Standard drilling cycle with dwell #1? "G82"
    821. Peck drill cycle with dwell #2? "G83"
    822. High speed peck drill cycle with dwell #3? "G73"
    823. Tapping cycle with dwell #4? "G84"
    824. Boring cycle #1 with dwell #5? "G88"
    825. Boring cycle #2 with dwell #6? "G89"
    826. Back boring cycle with dwell #7? "G87"
    827. Left hand tapping cycle with dwell #8? "G74"
    828. Fine boring cycle with dwell #9? "G76"
    829. Hole making cycle with dwell #10?""
    830. Hole making cycle with dwell #11?""
    831. Hole making cycle with dwell #12?""
    900. Work shift #1? "G54"
    901. Work shift #2? "G55"
    902. Work shift #3? "G56"
    903. Work shift #4? "G57"
    904. Work shift #5? "G58"
    905. Work shift #6? "G59"
    906. Work shift #7? "G54.1P1"
    907. Work shift #8? "G54.1P2"
    908. Work shift #9? "G54.1P3"
    909. Work shift #10? "G54.1P4"
    910. Work shift #11? "G54.1P5"
    911. Work shift #12? "G54.1P6"
    912. Work shift #13? "G54.1P7"
    913. Work shift #14? "G54.1P8"
    914. Work shift #15? "G54.1P9"
    915. Work shift #16? "G54.1P10"
    916. Work shift #17? "G54.1P11"
    917. Work shift #18? "G54.1P12"
    918. Work shift #19? "G54.1P13"
    919. Work shift #20? "G54.1P14"
    920. Work shift #21? "G54.1P15"
    921. Work shift #22? "G54.1P16"
    922. Work shift #23? "G54.1P17"
    923. Work shift #24? "G54.1P18"
    924. Work shift #25? "G54.1P19"
    925. Work shift #26? "G54.1P20"
    926. Work shift #27? "G54.1P21"
    927. Work shift #28? "G54.1P22"
    928. Work shift #29? "G54.1P23"
    929. Work shift #30? "G54.1P24"
    930. Work shift #31? "G54.1P25"
    931. Work shift #32? "G54.1P26"
    932. Work shift #33? "G54.1P27"
    933. Work shift #34? "G54.1P28"
    934. Work shift #35? "G54.1P29"
    935. Work shift #36? "G54.1P30"
    936. Work shift #37? "G54.1P31"
    937. Work shift #38? "G54.1P32"
    938. Work shift #39? "G54.1P33"
    939. Work shift #40? "G54.1P34"
    940. Work shift #41? "G54.1P35"
    941. Work shift #42? "G54.1P36"
    942. Work shift #43? "G54.1P37"
    943. Work shift #44? "G54.1P38"
    944. Work shift #45? "G54.1P39"
    945. Work shift #46? "G54.1P40"
    946. Work shift #47? "G54.1P41"
    947. Work shift #48? "G54.1P42"
    948. Work shift #49? "G54.1P43"
    949. Work shift #50? "G54.1P44"
    950. Work shift #51? "G54.1P45"
    951. Work shift #52? "G54.1P46"
    952. Work shift #53? "G54.1P47"
    953. Work shift #54? "G54.1P48"
    954. Work shift #54? ""
    955. Work shift #55? ""
    956. Work shift #56? ""
    957. Work shift #57? ""
    958. Work shift #58? ""
    959. Work shift #59? ""
    960. Work shift #60? ""
    961. Work shift #61? ""
    962. Work shift #62? ""
    963. Work shift #63? ""
    964. Work shift #64? ""
    965. Work shift #65? ""
    966. Work shift #66? ""
    967. Work shift #67? ""
    968. Work shift #68? ""
    969. Work shift #69? ""
    970. Work shift #70? ""
    971. Work shift #71? ""
    972. Work shift #72? ""
    973. Work shift #73? ""
    974. Work shift #74? ""
    975. Work shift #75? ""
    976. Work shift #76? ""
    977. Work shift #77? ""
    978. Work shift #78? ""
    979. Work shift #79? ""
    980. Work shift #80? ""
    981. Work shift #81? ""
    982. Work shift #82? ""
    983. Work shift #83? ""
    984. Work shift #84? ""
    985. Work shift #85? ""
    986. Work shift #86? ""
    987. Work shift #87? ""
    988. Work shift #88? ""
    989. Work shift #89? ""
    990. Work shift #90? ""
    991. Work shift #91? ""
    992. Work shift #92? ""
    993. Work shift #93? ""
    994. Work shift #94? ""
    995. Work shift #95? ""
    996. Work shift #96? ""
    997. Work shift #97? ""
    998. Work shift #98? ""
    999. Work shift #99? ""
    152. Line rapid move XY.
    n,rapid_move,xr,rotary_xyr_angle,
    153. Line feed move XY.
    n,cc,feed_move,rotary_xy_f,rotary_xyr_angle,feed_r ate
    154. Line rapid move XYZ.
    n,rapid_move,xr,rotary_xyr_angle,zr
    155. Line feed move XYZ.
    n,feed_move,rotary_xy_f,rotary_xy_angle,z_f,feed_r ate
    156. Line feed move XY on Leadin.
    n,cc,feed_move,rotary_xy_f,rotary_xy_angle,feed_ra te
    157. Line feed move XY on Leadout.
    164. Arc move.
    n,g_arc_move,rotary_xy_angle,arc_center,z_f,feed_r ate
    170. High speed peck drill canned cycle.
    n,g_canned_cycle,g98_g99,rotary_xy_f,rotary_xy_ang le,drill_depth,reference_plane,peck_drill_incremen t,canned_feed_rate
    171. Left handed tapping canned cycle.
    rigid_tapping_start
    n,g_canned_cycle,g98_g99,rotary_xy_f,rotary_xy_ang le,drill_depth,reference_plane,canned_feed_rate
    172. Fine boring canned cycle.
    173. Drill canned cycle cancel.
    rigid_tapping_end
    174. Standard drill canned cycle.
    175. Standard drill canned cycle with dwell.
    n,g_canned_cycle,g98_g99,rotary_xy_f,rotary_xy_ang le,drill_depth,reference_plane,canned_feed_rate,dw ell
    176. Peck drill canned cycle.
    177. Tapping canned cycle.
    rigid_tapping_start
    178. Boring cycle #1 canned cycle.
    179. Boring cycle #2 canned cycle.
    180. Back boring cycle canned cycle.
    181. Boring cycle #1 canned cycle with dwell.
    182. Boring cycle #2 canned cycle with dwell.
    183. Canned cycle drill point format for standard drill canned cycle NO SUBPROGRAMS.
    n,rotary_xy_f,rotary_xy_angle,z_f,canned_feed_rate
    690. Prefix for X Rotation Move? "A"
    64. Arc move XY.
    n,g_arc_plane,g_arc_move,x_f,y_f,arc_center,feed_r ate
    65. Arc move YZ.
    n,g_arc_plane,g_arc_move,y_f,z_f,arc_center,feed_r ate
    66. Arc move XZ.
    n,g_arc_plane,g_arc_move,x_f,z_f,arc_center,feed_r ate
    640. Prefix for arc Z center? "K"
    691. Prefix for XY Machining Plane? "G17"
    692. Prefix for XZ Machining Plane? "G18"
    693. Prefix for YZ Machining Plane? "G19"
    10.Rotary axis index string
    n,"A",rotary_angle
    Apr 2008
    1577
    n,"M33"
    There's the problem. Delete the line:
    n,"M33"
    and you should be good to go!
    Right below that is the Rigid tapping end code. If you don't need the M32 you can delete that as well.
    Apr 2008
    1577
    I want to make clear that you should NOT delete this line:
    Just the n,"M33" below that.
  1. Bobcad cam outputs M33 G84 G98,I dont want M33.
    By sve0019 in forum Uncategorised CAM Discussion
    Last Post: 10-18-2010, 07:35 PM
  2. different outputs
    By oest in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-23-2010, 04:59 AM
  3. X3 - How to get arc outputs in the X/Z plane?
    By colton_m in forum Mastercam
    Last Post: 03-03-2010, 07:22 AM
  4. inputs outputs
    By sintratech in forum Machines running Mach Software
    Last Post: 04-01-2007, 08:17 PM
  5. Inputs/Outputs
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 08-03-2006, 03:52 AM
