585,931 active members*
5,117 visitors online*
Thread: need post
    Mar 2009
    291
    need post
    Does anybody have a post for a toyoda fh55 with a 15m control?Im looking for one that has the predator header included.
    Jul 2008
    9
    Mar 2009
    291
    post
    Yes they have one post for toyoda. doesnt say what control .doesnt have the predator header .I did down load it though. ill try it when i get the machine running.
    Jun 2008
    1838
    Quote Originally Posted by 1234567 View Post
    Just paste the header into the post using Notepad.
    "(BEGIN PREDATOR NC HEADER)"
    "(MACH_FILE=3AXVMILL.MCH)"
    output_tool_list
    output_stock_definition
    "(END PREDATOR NC HEADER)"
    The line "(MACH_FILE=3AXVMILL.MC)" calls up a specific Template in Predator, in this case the "3AXVMILL" Template so in the drop down list at the top of the Predator you must select the "3AXVMILL" to match what is in your header.
    If you wanted to use a different Template for example the "DEFAULT" one then you would have to change the line in your header to "(MACH_FILE=DEFAULT.MCH)"
    Regards
    Rob
  1. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2010, 07:23 PM
