585,766 active members*
3,971 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Apr 2015
    10
    Re: Traub-Experts
    HI thanks for your reply,
    Yes the problem was in the lower operators panel, i air cleaned the board and re-adjusted a twisted ribbon connector.
    all is fine ,
    thanks ,
  2. #22
    Apr 2015
    10
    hello, Mr Sauamikat'
    you have helped me in the past with your knowledge.
    i have a problem with a Traub TNS 30/42.
    the machine will power up ok , no alarms .
    when the drives and hydraulic button is pressed the drives are switched on but they are working for only ten seconds and then switching off. this is repeated every time i press the drives on.
    there are no NC alarms just A016 when the drives go off, but the alarm is cleared by switching drives off button.
    the main drive unit in the machine cabinet is showing a LED indicator status : error on power side or UE OFF at RF ON , the main drive is a AMK arnorld Muller D-7312,
    can anyone advise with this problem please.
    kind regards
    Mr Des Williams
  3. #23
    Oct 2015
    4
    I bought a lathe tnl 32 g, when I turned on the power, the screen does not turn on, I pressed several buttons on the display but the screen does not work. When I charge to turn off, the screen flashes once .. Can anyone help me?Click image for larger version.
  4. #24
    Sep 2019
    Hello everyone,
    we just buy a TNL12/7 1999 TX8I and allredy have some problem. After we start the machine we recive an error code Z071/1 on all axes.Can sombody help us with an advice or a setup manual(parameter list and configuration)?
    best regards
  5. #25
    Nov 2012
    4
    HELLO Die Traub-Experten
    I have Traub TNS 60 I need to input the parameters kindly publish the method for manually inputing the parameters.
    Saja
  6. #26
    May 2019
    7
    Re: Traub-Experts
    good afternoon
    could you help me, I try to communicate with the mc161 card in a TRAUB TNM42 control system TX8F, I need to reset parameters, I have 4 computers without data and 2 with all the information, could you please help me
  7. #27
    May 2019
    7
    Re: Traub-Experts
    Quote Originally Posted by desmond4518 View Post
    kind regards
    Mr Des Williams
    que tal saludos ami me paso algo similiar y el problema era el contactor mk1 de la bomba del hidrahulico la cual botaba su proteccion termica
  8. #28
    Jun 2020
    Re: Traub-Experts
    Hello,
    We are running a TNX65/42 and have lost our MSP orientation. How can we reset it to the desired zero.
    I have not been able to find a screen that gives it or shows actual C axis position.
  9. #29
    Feb 2021
    Re: Traub-Experts
    Hello,
    On our traub tnc65 machine, the spindle and counter spindle are not concentric, how can it be set?
    I do not have the documentation for the machine
Page 2 of 2 12
  1. DNC Traub
    By ddorin in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2011, 01:42 PM
  2. Traub TNM42!
    By denilson in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2010, 04:43 PM
  3. traub TNL 32 G
    By dominikbedziak in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-29-2010, 10:12 PM
  4. traub TNL32G
    By dominikbedziak in forum Servo Motors / Drives
    Last Post: 04-29-2010, 09:48 PM
  5. post for a Traub
    By one4you in forum FeatureCAM CAD/CAM
    Last Post: 05-01-2009, 12:47 PM
